Microsoft Xbox 360 Console Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xbox pack light is red not orange - Microsoft Xbox 360 Console
john o grady
Level 2:
Novelist:
  • Expert 99 Answers
  • Posted on Jan 22, 2011
john o grady
Expert
Level 2:
Novelist:
Answers
99
Questions
Helped
15436
Points
331
Hi there, This can be a result of a few things that have happened. There may have been a power surge and your power supply switched to safety mode to prevent damage to your xbox. It also might just have overheated, in which case just let it cool down in a well ventilated area for a couple of hrs and try it again. You can also try just plugging into a different power source like a mains supply instead of extension lead if you had it plugged into one. If using a different mains or cooling down don't work then I'm afraid you will need to replace your power supply. Hope this helps
Light on the power pack stays orange and now my console is flashing 3 red lights due to this
That is the Red Ring of Death. A very well known problem, you might be able to get the 360 repaired by microsoft for free.
10helpful
2answers
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
2answers
The power pack box to the system shows a red light...cant get the system turned on.
If it's showing a red light, it may no longer be good. You can buy an XBOX 360 power supply & cord at the following website:
http://store.richspsxparts.com/ustexb360pos.html
My xbox will not turn on
Yes this is the overheating problem you need to stop the heat build up you can use a good guide or send it in to get it fixed.
No power in console, but light is on ,on the power pack
This is normal. The light will always be on if the power pack is plugged into the wall. There should be no lights lit on the Xbox if the power is turned off, but the power pack will still have an orange light.
One red light on console error 74 and orange light on power pack xbox 360 elite
Contact xbox if it is still under warranty then when you get it back sell it and buy a Playstation 3
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
1helpful
My xbox has three red flashing lights, how can I get it working again?
My sons Xbox had the 3 red lights! It depends what colour of light is showing on your power pack the colour indicates what the problem is! The light will either be red,amber or green, my sons light was amber and that was due to a faulty power pack, Microsoft were very obliging and replaced the power pack free of charge,it arrived in 3 working days! Here is a link that will take you through the different lights and how to fix the problem!
http://support.microsoft.com/kb/907534
Hope this helps, good luck!
Flashing Power Pack
Amber light is ok its when its red that is the problem, this might be your 360 that is faulty and until we have a closer look we would not be able to help further. You could try a different power supply from a mate, if the console works with a different power supply then you know its your supply thats faulty. but if the 360 still will not turn on then its the 360 at fault. Be carefull when using different power supplies as there are currently i think 4 different revisions and all have different power ratings. We could look at this for you www.fixmyconsole.co.uk
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
