Adobe Acrobat Reader 3.0 for PC/Unix/Mac Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There occurs an error while installing adobe reader which is about locating , the error number is 1606, n please do instruct me in that.
Anonymous
Level 3:
Guru:
  • Master 443 Answers
  • Posted on Jan 22, 2011
Anonymous
Master
Level 3:
Guru:
Answers
443
Questions
Helped
107072
Points
1339
Hi Gopinathan81,
I have done some google work on the error code which you had and found the resolution..
Try this if it is not working then post back we will be happy to help you.
Hope this help.
Cheers!!!
2answers
I'm getting this message every few minutes on a Vista system. Acrord32.exe-No Disk "there is no disk in the drive\Device\Harddisk4\DR4.
These instructions apply If you have "Adobe Acrobat Reader" installed, not if you have the paid for, full suite "Adobe Acrobat".
1. Completely uninstal "Adobe Acrobat Reader"
more details (troubleshooting):
https://forums.adobe.com/thread/755658
2. Reinstall (if you so choose) "Adobe Acrobat Reader"
http://get.adobe.com/reader/
or use an alternative (less bloated) PDF-reader:
http://www.tracker-software.com/product/pdf-xchange-viewer
Adobe reader 9.3
Make sure your downloaded the correct software. There should be a 32-Bit and 64-Bit version.
Hope this helps ^^. Please dont forget to rate, Thanks.
If still no please email me at [email protected] and ill assist you from there.
8helpful
I purchased my Sony prs 600 a few hours ago replacing my older Sony reader. I get an error message -474. I cannot download books I have purchased from Sony reader store any suggestions?
The error -474 or -1106 sometimes occurs after an issue with validation or authorization in the Reader (eBook) Library software.
From the Reader (eBook) Store, deauthorize the computer.
Close the Reader (eBook) Library software.
Reopen the Reader (eBook) Library software.
Sign in to the account to authorize the computer again.
Try again to download a book purchased previously from the Reader Store.
If the error still occurs, proceed with the steps below:
Install the Adobe Digital Editions software. Use the installer at http://www.adobe.com/products/digitaleditions.
Setup Assistant will be displayed in the Adobe Digital Editions program.
Click the Authorize button and then the Finished button.
Deauthorize the computer using Adobe Digital Editions
NOTE: Press Ctrl-Shift-D to deauthorize the computer.
Reopen the Reader Library.
Go to the Reader Store and sign in.
You will now be able to download an eBook and transfer it to the Reader device.
Resource 2
If issue persists, deauthorize the computer, then follow the steps below.
Browse to http://www.adobe.com/products/digitaleditions/ and download the software.
please sign in with the Adobe ID and password when prompted .
Now, click on the "Activate" option and close the Adobe Digital Editions Software
Reopen the Reader Library software.
Sign in to the Reader Store.
Please perform the above steps and that should resolve the issue.
ERROR 1606. Could not access netwrok location %APPDATA%\
I think the server where you have download the software has problem. So try to download from other place. I recommend you to dwonload from www.Adobe.com or www.rapidlibrary.com
2answers
Want to install Adobe 9 but keep getting Error 1606
Error "1606: could not access network location \Startup" occurs when installing Adobe Creative Suite 4 products or Acrobat (8 or 9)Check out this website for the fix to this issue.
http://kb2.adobe.com/cps/402/kb402867.html
1helpful
Error 1606: Can not locate network location; during Adobe Acrobat Reader 9.1 and Microsoft Office Standard Version 2007 install
On another computer with a cd/dvd drive hooked up to the internet Go to HP.com/support and, download the drivers for vista for your computer then install them on your malfunctioning computer
3helpful
3answers
Error 1606 with adobe
With many thanks to rlessmue on CNET forum... this is what worked for me (for both Acrobat Standard 8.0 & Photoshop CS2):
http://forums.cnet.com/5208-6122_102-0.html?forumID=44&threadID=106141&messageID=2913550
...I found an easier fix for "Error 1606" by rlessmue - 9/12/08 11:44 AM In reply to: Your suggestion worked! by jarjar467-news
Receiving "Error 1606: Could not access network location Startup"
To fix, Adobe seems to be having a conflict with Microsoft Office.
NO need to remove Microsoft Office (if you are having problems with install, upgrade or removal)!
Follow these steps:
1) Open Regedit, (Start -> Run -> (type in) regedit
2) Inside Regedit go to:
HKEY_LOCAL_MACHINE -> SOFTWARE -> Microsoft -> Office
3) Right click on "10.0" folder and select "Export" (and save a copy to your desktop).
(You can do this for the other number folders (like 9.0, 11.0, 12.0) if you want to be sure).
4) Verify that the file(s) have been put on your desktop.
5) Next, delete the folder "10.0" (or the folders you exported) from with in the registry (right-click - delete, confirm)
6) Install, upgrade or remove Adobe Acrobat 8.0...when done...
7) Go to the desktop and click twice on the "10.0" file (and each of the other files) and add back to the registry!
8) You should verify that MS Office products still work, and Acrobat should work too! That's it!
2answers
Installing problem...
Try to see if you can resolve with the steps given here
first link
Second option
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
