Question about Singer 5050 Mechanical Sewing Machine
Putting on the tension wire by the needle.
When I was putting on a new needle for my 5050 Singer, the little wire tension (I don't have a name for it!) that attaches itself to the needle structure, came off as well. The problem is, is I don't have a clear picture of it to see how to re-connect it. I have tried pulling down pictures but they are all too small, and my manual doesn't have one of it. It seems to fit around the little screw that holds the needle in place but I can't work out how.
The only other alternative is to drive down to a Sewing Machine Shop and hopefully find one the same as mine that will help. I'm hoping I don't have to go to that extent yet, and you could download a picture of it in position for me.
Thank you
Lesley
  • 323 Answers
It is a thread guide and if you don't reconnect it your machine will still work.Don't worry about it too much.
To reinstall it you need to place one end around the screw in such a position so that the guide will travel behind the needle bar, to the left side of the needle bar and then to the front of the needle guide. When you have it in this position you should have no real problem screwing it back on.
sewman7
Posted on Jul 16, 2008
2 Suggested Answers
  • 980 Answers
SOURCE: I have a singer 5050 how much tension do I need
Top tension about 4 or 5, use a good mercerised thread only, make sure you do not have the bobbin tesnion too tight, slacken the screw anti clockwise on the bobbin case if it is
Posted on Jun 27, 2010
Have new never used singer simple 3232, tension was tight n I tried to use it n locked asap hand wheel/ pedal frozen needle wont move. no thread is apparently at fault. How do I proceed?
Return it if you can, I have seen these brand new with seized needle bars before. You can try putting a drop of oil on the needle bar where it goes through the supports and gently working the handwheel until you can get it moving.
Jan 04, 2017 | Singer 3232 Simple Sewing Machine
Singer 5050 sewing machine threads gathering under fabric and becoming knotted. how do i fix this
Try a new needle and rethreading. Check your threading by putting the presser foot up , then pull thead, should move smoothly, now put presser foot down, now pull, it should barely move. This usually seats the thread in the tension discs.
Jan 02, 2011 | Singer 5050 Mechanical Sewing Machine
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
The thread keeps coming out of the needle on top when I start sewing. Any help would be appreciated. I tried putting the needle in again, I tried taking the bobbin area apart and putting it back together...
I have had that problem to. All I had to do was adjust the tension and make sure that the thread had enough slack and it was fine. That is slack after you pulled it through the hole in the needle.
Hope this helps you.
Oct 30, 2009 | Singer 5050 Mechanical Sewing Machine
When I tread the machine and lower the foot, press the peddle it appears to be sewing but nothing sew together.
the problem of your machine is your needle. put your needle in his right position. adjust the tension. and it is ok. promise
Oct 08, 2009 | Singer 5050 Mechanical Sewing Machine
Help in threading singer 491
that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Oct 01, 2009 | Singer 5050 Mechanical Sewing Machine
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5050
Does your sewing machine create unwanted loops or does the thread snap on the top of your machine? Does it seem like your machine does not want to work with you? Your problems could be related to tension. First off, I recommend putting a white thread in the bobbin and a black thread through the needle. This will be imperative as you will need this to learn which thread is your main problem.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis. If you see loops of black, your needle tension is too loose or your bobbin is too tight. First try tightening the main dial on your machine to a higher number. If that does not work, try using a small screwdriver to turn the screw underneath the bobbin-case in the front of your machine clockwise. Please remember that even a little turn can mean everything in your work. I recommend only turning it 1/4th of a turn each time you test it. Now if the loops were white, it means your bobbin tension is too loose. Do the same as above, tightening the screw clockwise with a screwdriver. If it seems too tight, please do loosen it and try to find a happy medium between your needle thread and your bobbin thread. If the thread snaps, your tension is too tight. Do the reverse of the above. Either lower the number on your needle if the thread is snapping or turn the screw on the bobbin-case counter-clockwise. Again, each little bit of the turning counts, so only turn it about 1/4th the way. It is always good to be extra careful. Keep working with both until you get a nice even stitch. An even stitch means the black should be on the top of your fabric and white should be on the bottom. It is perfectly okay if you see a little speck of one on the other side. If all fails, try putting two drops of sewing machine oil in your machine and let it run through for about five minutes. The mechanisms might be a little overworked and are having a problem with your machine. It is good if you keep a lot of fabric scraps available in case you over oiled. You do not want to be working on a difficult project for your sewing machine only to spit some oil on it. Keep sewing on the fabric scraps until there is absolutely no residue from the oil. Putting any more that 2 drops as stated earlier might cause more problems than you expect. Always use the oil sparingly. If none of the above solutions have worked and you feel frustrated by your machine, a local Sewing Repair Shop visit should only run you about $40 and is highly recommended for your machine. A professional can tell you if what’s wrong with your machine is fixable at-home or not. A full repair for older machines before working with them is highly encouraged.
Sep 15, 2009 | Singer 5050 Mechanical Sewing Machine
Singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Nov 02, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
42 people viewed this question
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
