Hitachi 50VF820 (LCD projection)randomly turns off, all three lights (temp,lamp,power)blink then the set turns back on after approx. 30-45 seconds. Lamp was changed approx. 4-5 months ago. Cleaned out all vents. Problem still exists.
  • rkdavis82 Jul 21, 2008
    The problem is not solved. The fan just made the TV not turn off and back on as much.
I believe I may have solved this problem by putting a small fan blowing on the intake of the Lamp fan. I put the fan in place and the TV has not turned off randomly since. That was only a day ago so I'll see if it is a permanent fix. If so I will probably try to mount the fan on the back of the TV out of sight.
Posted on Jul 17, 2008
I just replaced the lamp in my Hitachi 50vf820 tv and it comes on for a second then cuts out and blinks red temp light.
Make sure all the fans are working correctly. If the problem persists then it might be the ballast, the power supply or a bad temp sensor.
Mar 26, 2014 | Hitachi 50VF820 Projection TV
I have a hitachi 50vf820 with green tint to it
Its a DLP type set that uses a lamp for a light source.
With the color turned to zero stand back and examine the image.
If mostly all green or areas are green you may have a issue with the optical light engine--either damaged inside from the heat of the lamp or the portion that processes red, green, and blue information bad.
Jun 03, 2012 | Hitachi 50VF820 Projection TV
Hitachi 50vf820 ultravision tv. replaced lamp now tv will not turn on and lamp light still blinking
Did you make sure all doors and screws are back in unit biggest mistake is not putting door back on mechanism that wont let lamp light without it on please start here
Mar 03, 2010 | Hitachi 50VF820 Projection TV
Hi I have a hitachi LCD projection TV my lanp and
yes you need a lamp about as sure as anyone can be without looking take lamp out see if its brke inside or has any whit smoke spots in it
Feb 06, 2010 | Hitachi 50VF820 Projection TV
Lamp light and temp light blinking on 50vf820 .please tell me if unit has a air filter for fan
It could be one of the fans has stop working or it could be just the bulb needs to be replaced. Does the set even come up.(show a picture)? If not its more than likely the bulb. Hope this helps.
Nov 02, 2009 | Hitachi Televison & Video
Lamb out Could I replace
Refer to your owners' manual. Lamp replacement is very easy.
May 14, 2009 | Hitachi 50VF820 Projection TV
Tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Apr 29, 2009 | Hitachi 50VF820 Projection TV
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
