after cleaning the metal fins and the complete inside of the Sharper Image MIDI unit, the red light will come on within 1/2 hour. Is there something I missing or doing wrong.?
-   same problem. red light after cleaning and static noise. will try intensive cleaningas described. -   Guest
Aug 22, 2008
-   Red light stays on after cleaning all applicable areas several times. Not impressed.-   Guest
Aug 10, 2008
-   red light is on after cleaning-   Guest
Jul 29, 2008
-   I have same problem with RED LIGHT. I have cleaned it and turned it upside down, but when I turn unit on the blue light illuminates, then I hear a sound like static, then red light illuminates -   charlie2005
Jul 21, 2008
-   we cleaned our mashine as good as one can but the red light keeps coming on. What are me missing?-   Guest
i had a similar problem with my pro. the wires would get a heavy white build up that would not come off with the wire cleaner so i had to take the unit apart and clean the wires by hand and that worked for me. you may be able to reach them if you put a Q-tip in the end of a straw.
Was this helpful?
Yes
No
Solution #2
posted on Aug 26, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
unplug throw in the middle of the road, put a paper bag over your head go out beside it and scream like a chicken.
Red lamp came on I have cleaned it very well but the red lamp continues to light shortly after...
(More)
Red lamp came on I have cleaned it very well but the red lamp continues to light shortly after cutting the unit on
