Question about Star 530FD Deep Fryer
Star deep fryer
Will not get hot when turned on
  • 57 Answers
FIRST THING I WOULD DO IS CHECK THAT THE MAINS RED LED IS LIGHTING IF NOT CHECK THE FUSE IN THE PLUG IF IT IS BLOWN THEN YOU WOULD HAVE TO LOOK AT THE ELEMENT AND CHECK IT FOR RESITANCE ABOUT 100 OHMS NOT A DEAD SHORT IF THIS IS OK THAN CHECK IF THERE IS A FUSABLE FUSE OR THE THERMOSTAT CONTROL MAKE SURE THAT YOU CAN HEAR IT CLICKING WHEN TURNING THE DIAL IF THERE IS NO SOUND YOU CAN ADJUST IT OR REPLACE IT
Posted on Jul 17, 2008
I have a star deep fryer that over heats the oil and then trips the breaker on the back of the fryer.
Has to be a stuck thermostat or a bent or broken bulb, tube in the fryer oil. When replacing the control be careful not to bend the tube to much to pinch it closed. This is a very small pipe. Check by turning the thermostat from low to high and see if it will turn off the fryer. It could be out of calibration but unlikly when the high limit kicks off.
Oct 08, 2014 | Star Max Electric Counter Fryer 301-HLD
I change the thermocople but now the burner don't lit
Hi there!
Check if the thermocouple is properly heated by the pilot flame.
Check also if the hi limit has continuity across the terminals.
Regards.
Apr 23, 2012 | Star 30lb Gas Counter Top Deep Fryer 630fd...
My Tri Star 4050 fryer is causing soot to collect on the ceiling of my trailer.
You are cooking too hot....Turn the temperature down, and if it still does that, try using it outside or under a vent or hood... That's generally a better idea, to use the fryer under a vent, so it can vent that hot, oily air outside to start with....Thanks, Susan
Sep 08, 2011 | Kitchen Appliances - Others
Need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
May 07, 2009 | Star 530TD Deep Fryer
Please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Jul 08, 2008 | Wells LLF-14 Deep Fryer
Star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
May 15, 2008 | Star 530FD Deep Fryer
Fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
Mar 18, 2008 | Star Kitchen Appliances - Others
Cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Oct 15, 2007 | Rival CF153-WM Deep Fryer
Star deep fat fryer model #EM14
You should determine how many amps the unit is pulling, you will need an ammeter to do this. Continuity through the internal circuit breaker does not determine the current being pulled by fryer only that it can pull current. If the fryer is pulling more than 50 amps the problem will be in the fryer, if it is less than 50 and the breaker trips you could have a faulty breaker.
Aug 22, 2007 | Star Manufacturing TSF-6575 Deep Fryer
Star 530FD Deep Fryer Logo
127 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
