Kingston DT100 4GB slow to format under Vista
  • emondragon Jul 17, 2008
    I've tried quick formatting using Vista and it formats quickly but the same flash drive formats quickly using Windows XP using the full format option. With Vista it takes several minutes to full format. This is my second DT110 having the same problem. Thank you.
  • 781 Answers
Did you try quick format
Posted on Jul 16, 2008
  • David
    David Jul 17, 2008
    I have never had any problems doing quick format on thumb drives hard drive etc if I have to format I always use quick.
    there are programs out there to format all types of cards from cameras etc hope this helps.
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
Jun 13, 2011 | Kingston 2GB Secure Digital Memory Card
Memory was not format and memory to connect pc after pc was very slow
when you want format but it can't be format
- Some file have access by system, commonly it's Virus
- you can try format on safe mode system windows
- you can try format in linux system
- commonly your device is broken
Mar 17, 2011 | Kingston 2GB Secure Digital Memory Card
Hi i have a 128GB Kingston USB memory that I have tried to format it to NTFS format, but it would not. but it works in fat32. I users windows vista sp2. have tried a program called HP USB Disk Storage...
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format USB memory
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 01, 2010 | Kingston Computers & Internet
How to upload pictures by my usb
That really is a matter of if when plugged in to the USB port of the computer you are using, if computer you are using can recognize the drive.
If you are using Windows XP, check "My Computer" and you should see the Kingston USB jump drive showing as an device icon.
In Vista and Windows 7 select "Computer" and you should also see the USB jump drive listed as a device icon.
If you are using a Mac OS X computer with your Kingston jump drive, providing the drive has been formatted with the Mac OS Extended (Journaled) format, or the MS-DOS format (which is readable on both Mac and PC platforms), it will show up
in the Finder sidebar and on your Desktop.
Either platform however, to load pictures onto your Kingston is easy, all you have to do is either copy the pictures from there respective folder or location and either right click on the Kingston 2GB HD icon and paste the pictures.
Or you can double click on the Kingston 2GB USB icon and paste or drag the pictures into the open window of the Kingston 2GB USB jump drive.
That is honestly as simple as it is.
Now, on the other hand, here are a few steps, if you want to upload to an online resource which allows photo uploads from another source, namely your computer..
When you use the upload feature of that website or webpage to upload your pictures to, no matter whether you are on a Mac or PC, you simply have to click that uploader's Browse or Upload button.
Next, simply locate the Kingston 2GB USB jump drive in My Computer, (Windows XP), Computer (Vista , Win 7) or Devices and/or Desktop (Mac OS X).
Then start selecting and uploading your pictures onto that website or webpage with your Kingston as the source drive.
Yes, I have given you a number of options, but hopefully you will see the ease of using any of these methods, again depending on what computer operating system you are using, how easy it is to upload photos from your Kingston (DTIU3/2GB) 2 GB USB Hard Drive.
Regards,
-Mactechtrainer
Jan 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How format flasch disk 125 GB KINGSTON win vista
start menu>
all programs>
run>type cmd
format it by typing.if your drive is f then type in dos
format f:
if your drive is g then type
format g:
go to my computer on windows vista right click on my computer click on manage
click on disk management
right click on your disk and format it
Mar 29, 2009 | Electronics - Others
Kingston flash 4 gb slow upload and download to my pc
is it plugged into a usb 2.0 port ? ... vista was always slow for moving files if that is what you use.... there is an update or patch for that from microsoft.
Robert
Jan 21, 2009 | Kingston flash memory card - 256 MB -...
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Very slow transfer to Kingston 8GB datatraveler
HI,
- Check if your PC is running at its maximum efficiency
- Close all side processes that are not of any use to you. This can be done by pressing :Ctrl+Shift+Esc and then going to processes. In there only close the processes that are under your user name and are of no use. NOTE: DON'T CLOSE "EXPLORER.EXE". This will free a sizeable amount of your RAM, making your PC generally faster.
- While copying anything, avoid multi-tasking as that will simply slow down your PC, causing a delay in the copying.
IF NONE OF THIS WORKS, then create a back-up of all the software in your Pen-Drive and then format it.
This should just about do it.
If still the problem persists, go to your dealer- your pen-drive must be in its warranty period.
Sep 30, 2008 | Electronics - Others
Hitachi 500 mb disk drive under Vista (Business)
to work with vista you must be having the minimum system requirements of 512 mb ram otherwise you will b experience slow...
if you have 512 mb ram or more than that then may be it s operating system problem just try reinstalling vista again....
and the drive in which the os lies may be in ntfs file system format ... so it is slow.....
Jan 12, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
