Question about Bushnell Trail Sentry 11-9200 Digital Camera
Sc card will not capture images. it did once and then card keeps saying to format when I put in my camera.
  • Robert Hill Aug 24, 2008
    I am having the same problem. My camera tells me it took a photo but the image is not counted on the lcd screen or on the memory card. Any ideas???
Is your sd card to large. The camera says only up to 1gb card.
Posted on Aug 27, 2008
Camera wont read the disk
Coolpix cameras do not have a disk; they use an SC memory card. When you put a new SC card in the camera, you must format it before you use it. Go into your camera's Menu. Under Setup, you will find "Format memory card". Once your SC card is formatted it should work.
Oct 01, 2013 | Nikon Coolpix L22 Digital Camera
THE IMAGES CAPTURED AT NIGHT ARE SO DARK THAT WE ARE UNABLE TO VIEW THEM. WE CAN SEE SHADOWS IF DEER BUT CANNOT FIGURE OUT HOW TO GET AN ADEQUATE PICTURE AT NIGHT.
Turn camera off take out battery's and sd card. Once everything is out put it to the on postion for about 2-3 min. Then put battery's back in with the camera being on still leave sd card out. Once it says no card turn camera off then put sd card back test in dark. If still not working call Moultire 8006533334 option 1 and 1 for a live person.
Sep 30, 2013 | Moultrie Game Spy C-90I 10.0Mp Scouting...
My camere keeps saying that MEMORY IS FULL
there is only a certain amount of storage that a camera can hold internally and the amount it can hold on a card depends on the size but both will and cal fill up... what you have to do it transfer the images to a computer so you have a copy then format your camera or card depending on which one you are using.. once the card is formatted all of the images on the card or camera will be gone forever and that is why you need to transfer first but once you do format it will clera out space for you to shoot again.
Nov 16, 2012 | Cameras
How do I format a SD card in aKodak V570 digital camera
Make sure you have an SD card. If your card is 4GB or larger then it's actually an SDHC card and won't work in your camera.
Aug 18, 2012 | Kodak EasyShare V570 Digital Camera
When viewing a recently taken picture it is blank saying unidentufied image how do you fix
Once you have saved the images you want to keep, try to format the card using the camera's menus. If that does not work you could format the card on PC by using a card reader, and then format again in the camera to make sure it is fully compatible. Hope it helps
Dec 12, 2010 | Canon PowerShot A570 IS Digital Camera
I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
Capture Error
This is somewhat of a long-shot, but try formatting both of your cards in your camera. I once bought a digital camera and tore my hair out with similar symptoms until I formatted the card in the camera. If the problem persists, I'd call Kodak. Good luck!!
Sep 13, 2005 | Kodak DCS 14n Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Bushnell Trail Sentry 11-9200 Digital Camera Logo
201 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
