Question about Garmin Forerunner 305 GPS Receiver
Forerunner 305 It turns on when on the cradle, but it is dead without cradle. Resetting does not work. thanks for any help. Filippo
  • cymrusteve Jul 20, 2008
    i've got the same problem. display looks fine when attached to the cradle. as soon as i remove the unit from cradle, the display goes blank and none of the buttons work.
    any ideas?
    Sniper:
  • 84 Answers
These units seem to be suffering from a bad connection on the inside of the unit. My wife's did the same thing. There was a connection inside that wasn't making contact. First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps. Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker. Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag. Let the unit sit over night. In the morning remove the tape.
Posted on Nov 13, 2009
NO life in my Forerunner 305
Try first changing the battery if you have but if not better call Garmin and let them repair or replace it if its still under warranty..
Hope that helps..........
Aug 04, 2008 | Garmin Forerunner 305 GPS Receiver
Can't find satillittes
Yes, resetting the Forerunner 305 would be just like resetting the Edge 305. If you are still unable to locate satellites with the Forerunner 305, please go to the following page on the Forerunner 305 Main Menu > Settings > General > About Forerunner and reply with your software version and GPS version.
HID KITS.
Jun 01, 2012 | GPS
I reinstalled the driver of my garmin forerunner 205 but it is still not recognized by my computer. it has been working for over a year but now I do not get any connection and the device is not recognized...
When you connect the unit to the cradle is there any reaction from the unit? I would try using a different USB port and cord first if this dosent fix your problem the next step would be to obtain a new cradle for your unit. They can be purchased here http://www.gpscity.ca/garmin-forerunner-205-305-charging-cradle.html.
Hope this helps!
Feb 25, 2011 | Garmin Forerunner 205 GPS Receiver
Forerunner will not charge
Test the charging cradle, there should be 5Vdc on the two outer most pins. Clean the contacts on the back of the Garmin with an eraser. Try resetting the Garmin by holding the Mode and lap/reset buttons with the power on. If this does not fix it then it's likely your battery needs replacing as per this response
http://www.fixya.com/support/t1061960-garmin_forerunner_battery_replacement
Feb 10, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 will not charge. Connection seems like it's not making between cradle and unit. If i wiggle it, sometimes it will briefly connect
Try cleaning the contacts on the back of the Garmin with an eraser then wipe the contacts clean on the Garmin and on the docking cradle with a rag dipped in methylated spirit or isopropyl alcohol.
Jan 15, 2011 | Garmin Forerunner 305 GPS Receiver
My Forerunner 305 was working when I ran today.  I just went to download and the 305 is completely dead.  No display when pressing 'on', and none in charging deck. What do you recommend? Thank you.
Press the reset and mode button simutaneously to reset watch
...then press the mode and start button at the same time for several seconds to start the watch up
Dec 22, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305
My husband is the best!  Here's what he did and now it works:
Hold the on/off button and mode button, then hit the lap/reset button.
Hope this helps!
Jun 21, 2008 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 won't charge
Question: My Edge or Forerunner 205/305 won't power on. Is there a soft reset that I can do?
From the Garmin web site.
--------------------------------------------------------------------------------------------------------------------------------------------- Answer: If a Forerunner or Edge 205/305 is unable to power on, a soft reset can be performed to un-freeze it. This will not erase any user data and is most effective if the device is connected to the computer while performing the reset.
To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version
May 26, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
193 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
