Question about Toshiba 32A43 32" TV
Vertical hold problem
My Toshiba 32A43 loses vertical hold on bright or mostly white scenes. It does this with it's tuner or the S-VHS input.Otherwise it has a great picture.
    Genius:
  • Toshiba Master
  • 1,689 Answers
There is a fault in either the input video amp, sync amp, sync separator, or the vertical scan generator areas. Most of the time this type of failure is caused by capacitors in these areas going off spec from age and use.
An experienced TV tech who is familiar with your set should be able to service this for you.
Jerry G.
Posted on Jul 16, 2008
Toshiba 40xv640u vertical ghosting
This will require a technician to resolve with some specially equipment.
May 14, 2012 | Computers & Internet
47 inch Toshiba LCD REGZA TV - screen has what looks like water stain or "woodgrain-like" shadows/artifacts. They go sort of vertical but are not straight, (look like wood grain shadows). Not real obvious...
The only way might solved this problem,to replaced the Tuner Signal board.If the board is replaced have same problem,then ur tv have some kind of dead pixels burns in.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 04, 2010 | Toshiba REGZA 47HL167 TV
I connected my VCR to a new Samsung LED TV with the white ,red and yellow audio/video cable connection. The VCR is working but I put the tv and the VCR on Cahnnel 3 and it does not show up on the TV, WHY?
Hi there
To answer your question;
You need to change the input(not channel) on your tv to video input. There should be a button on your remote and/or tv called input.
Otherwise you should find it in the menu under"input source"
Dec 28, 2009 | Toshiba M675 VHS VCR
White lines at top of screen - can't make go away
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
Nov 30, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Model # 32A43 brightness problem
Check for about 100 to 500 volts on G2 pin (screen voltage) when screen control is adjusted,if less than 200 volts,remove the g2 capacitor(from G2 to ground) on crt board,if screen regains brightness,then replace capacitor,if ok ,troubleshoot the ABL circuit,look for an open or changed valued resistor,also check your heater voltage.Good luck.Cheers.
Nov 04, 2009 | Toshiba 32AF43 32" TV
Vertical rolling during bright scenes w/ high white content
power supply voltage not stable check capactors and look for dry joints.
May 02, 2009 | Samsung TXM3297HF 32" TV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Apr 17, 2008 | Televison & Video
Do I need a lamp/bulb?
Hi, Yes this is what you call a burn in , sence the part of the screen was blank out for so long the rest of the screen used slowly burt in, depending how bright your setting was place at, this is also the same affect when people keep there tv on the same chanel were there is only wrigting and no movement or video game or famous for that. It wouldn't be the bulb , they only project light,
Regards
What About Bob
Feb 25, 2008 | Sony KP-51WS510 51" Rear Projection...
Toshiba 32A43 32" TV Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
