Question about Dell Latitude D531 Notebook
How do i reboot my laptop
I have tried f2 but it does not work how can i erase everything then reinstalled back?
  • yurip1011 Jul 17, 2008
    i tried f10 and nothing happen?
    Genius:
  • 2,028 Answers
You will need to use your recovery or operating system disc. At start up press F10 for the boot menu and select boot from CD. Skip the repair section of the set up and it will take you to the next section in which you can delete or erase the drive and install a fresh copy of the operating system.
Posted on Jul 16, 2008
  • Ryan Rogers
    Ryan Rogers Jul 18, 2008
    Some machines will blow right past the screen that prompts for the F10 to enter boot menu. If you see this screen you may need to be quick or try a few times to get there. If you don't see the screen with the prompt, then your problem is much deeper, probably with the motherboard.
  • Ryan Rogers
    Come to think of it, I beleive that it may be F12 on the Dell machine. Try F12, if that's it, sorry about misleading you. The Dell screen at start up will tell you which to press.
I want to wipe my laptp and restart with my Window 7 disc
You don't need anything special, just insert the Genuine MS Win7 CD-Rom and have the key code handy. Reboot your PC or laptop and choose a clean install. It will erase everything on your HDD.
Jun 29, 2014 | Gateway M685-E Notebook
Computer reboots itself after it has already rebooted itself and comes back to reboot screen
Sounds like a nasty virus. The only way to fix that would be to do a totatl reinstall of the operating system. When you do that though everything on the computer will be erased unless you hook the hard drive up to another computer and extract whatever you want to save.
Good luck!!
Aug 24, 2011 | Compaq Evo N800v Notebook
How do i format it to how it was when i got it
If you still have the disk for your OS then the process is fairly simple. Insert the disc and reboot the computer. While the computer is booting hold down ESC or possibly F2, F8, or F12. A boot menu should open up before your operating system begins to load and you should pick to boot from CD Drive. When the setup loads, go through the menus until you get to the section of where to install the OS. Delete all the partitions on your computer and then reinstall the OS on the new one. This will delete everything on your laptop and just have a clean copy of your OS.
If you don't have the original CD you can download and burn this onto a CD and boot it from CD. This will securely wipe your hard drive.
Apr 25, 2011 | Acer Aspire One PC Notebook
How do I erase my hard drive on a IBM T30 and reload the operating system and drivers.
Get an install disk for the operating system you wish to install (Make sure your computer is able to handle that operating system first), then put the disk in and boot to the disk. If your computer is not set up to boot to disk first then you will have to go into the BIOS, usually F2 of F12 on boot (whatever says press to enter setup), then change the boot settings from there.
Once you are inside the installer for that Operating System, it will give you an option to erase the hard drive you are wanting to install the operating system on, and restart new. Just so you are aware, this will reformat and ERASE EVERYTHING on that hard drive, so make sure that you have anything you want saved backed up somewhere else.
Once that is done, continue installing the operating system and then your hard drive will be erased, and the operating system will be reinstalled.
If you were just looking to erase a hard drive, then you can go to my computer, then right-click the hard drive you want to erase, then click format. THIS WILL ERASE EVERYTHING!
Hope this helps!
Mar 23, 2011 | IBM ThinkPad T30 2366 Notebook
Memory write/read failure at 040414C0, read 04EB04AB expecting 04EB04EB Decresing available memory Strike the F1 to continue, F2 to run the setup utility F2 and then I notice Available Ram Memory is...
Turn off the machine, remove the screws from the Memory Compartment door and check the Rams, if possible clean it (or them) using an eraser (pencil eraser) [clean the gold coating] and reinstall it/them. Now reboot the system before you close the door and check once again.
If you have two, then install one of them and check, or if you have only one, then you need to get a spare the try. In most cases, cleaning does the trick.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 18, 2010 | Dell Inspiron 9300 PC Notebook
I want oto reformat my computer
Lil, What do you mean by reformat? If it is the exact computer lingo then you want to erase everything from the HDD and reinstall Windows. is that what you want. If yes, then you must be prepared to lose all data unless you back it up before doing that and also reinstall all the programs that you have besides Windows, which in any case you are reinstalling. To do this you must first back up the data to a removable disk or a different partition of the HDD. Insert the Windows CD into the CD drive and reboot. Follow the instructions and after two reboots you will have a new installation of Windows. Now restore the data that you backed up. Also, reinstall all the programs that you had earlier or atleast those that you want now.
Jul 05, 2010 | Microsoft Windows XP Professional
Emachine D620. After system restored, password-original factory
install fresh copy of xp on different location of pc and extract files from ealier installed xp
May 08, 2009 | eMachines eMD620-5133 Notebook
Emachine laptop D620: reset password after system restored
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
May 08, 2009 | eMachines M6811 Notebook
Sony vaio vgnar51j screen not working..
when windows is loading try pressing F2 or F8 or F10 I don't remember off the top of my head which one will do it. But try to get to the system restore. (F2 i want to say) this will reinstall windows without erasing all your files.
Sep 15, 2008 | Sony VAIO GRX550 Notebook
Everything got erased
Try rebooting and pressing F10 (system restore on most HP's) and follow the prompts. Watch the screen closely when you turn it on at it is before everything
Apr 21, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Dell Latitude D531 Notebook Logo
66 people viewed this question
Alun Cox
