Question about Infinity BASSLINK Car Subwoofer
Red light comes on and then slowly goes out. No output
My basslink is hooked up and everything and when i turn my car on, the red light initially glows really bright and then in a matter of seconds goes away. Also, there is no sound coming out of the system. Both the amp's fuse and the fuse on the power cable are good. PLEASE HELP!!!!!
  • 109 Answers
For some reason you are not getting constant power to the system. What gauge power/ground are you running? Describe your system to me and we'll see what I can do to help.
Posted on Jul 17, 2008
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Everything is hooked up and the ps3 turns on but it doesn't show up on the T.V
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Basslink has no output, but Power LED and Servo LED always on.
One or more of the DC to DC outputs might be bad. Check the
/- 54v on the main PCB and the /-15v on the switching controller PCB.
Losing one side of the 15v will cause the limit comparator to rail and force the servo protection, even with no input signal.
Apr 02, 2010 | Infinity BASSLINK Car Subwoofer
Is the light on the infinity basslink suppose to be red or green
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook ups.......you should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
Jun 25, 2009 | Infinity BASSLINK Car Subwoofer
No picture but have green light
  1. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  2. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
May 24, 2009 | Video Game Consoles & Games
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
104 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
