Question about GE GSF25TGW
Won't stay cold and freezer won't freeze
We've been running this unit but we can't get the temperture down to the seeting just keeps getting warmer
  • 550 Answers
Most common cause is a gas leak there is not enough refrigerant left in the system for the compressor to compress.
this is a 'repair guy' repair to evacuate the system presurize with dyed water to find the leak, solder, re-evacuate, refill, takes a licensed person, refrigerants are dangerous ozone depleting and sometimes toxic.
Yellow pages, or a local friend who has had good results with a local tradie is the way to go.
Posted on Jul 16, 2008
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
I live in Winnipeg, Manitoba. I have an old Kenmore upright freezer. I would like to leave it in my unheated patio over the winter. Should I leave it plugged in, or can I unplug it and just watch the...
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
Nov 25, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have a GE Profile side-by-side Refrig (model PSW26PSSB SS). The freezer does not stay cold. Often my food thaws. I?ve placed a cup of water in the freezer over night and it does not freeze. My ice maker...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator and freezer running but... the refrigerator and freezer running but not cold enough to freeze a freeze pop and the refigerator doent stay cold at all spoils food fast 1 day
heatman101
Jun 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Sears model 253.9280212 UPRIGHT FREEZER NOT KEEPING FOOD COMPLETELY FROZEN. EVEN AFTER HALF OF CONTENTS HAVE BEEN REMOVED, REMAINING CONTENTS DO NOT COMPLETELY FREEZE. WHAT'S WRONG? HOW TO ID PROBLEM?...
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
May 06, 2010 | Freezers
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
What are the correct temps. for freezer and main refrigerator
Refrigerator should not be warmer than 40F. Optimal temps are 34F, this keeps your food cold without freezing it and slows down bacteria growth !
Freezer section no warmer than 10F. Normal temp 0F, optimal/recommended -10F (also for cold icecream) and for quick recovery in case of power outages.
I hope this helps.
Sep 25, 2009 | Frigidaire Refrigerators
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
GE GSF25TGW Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
