Dvd Hi, the dvd disk won't stay in the tv magnavox with dvd player
  • DEMARCO8622 Jul 16, 2008
    my magnavox tv/dvd ejects the dvds when i put them in at first it will say loading then it ejects them and says open
    Master:
  • 848 Answers
Most likely your lens that reads the disc is dirty. Basically what you do is open it up and clean the lens with either a cue-tip, a cue-tip dabbed in a little isopropyl alcohol, or canned air. I would recommend just a cue-tip . But if you use the alcohol rub the lens very lightly for about 20 to 30 seconds with the cue-tip. Canned air isn't good because you might blow the dust into the system.
Posted on Jul 16, 2008
    Genius:
  • 1,447 Answers
Hi-
If you have a DVD cleaner try cleaning it, check for physical damages as well on the disk door. If all fails better have a service technician open and check the gears of your unit. Hope this helps!
Thanks for using Fixya!!
    Brigadier General:
  • 3,614 Answers
The dvd disk won't stay in the tv magnavox with dvd player?? you mean it not play...
Kindly explain please...
Thanks
3 Suggested Answers
  • 56 Answers
SOURCE: dvd player won't work, says no disk
Greetings,
I do not have good news for either of you. These are notorious for having cheap lasers in them and their original purchase price usually makes a repair cost prohibitive. If you are having an intermittent problem where the disc will freeze - then play - then freeze - then play this is often the first indicator that the laser is failing. One easy way to confirm this is to play a compact disc in the player. CDs are easier for the player to read than DVDs are. If it plays CD and you continue to experience problems with DVDs this usually indicates a laser failing. Remember, when buying a consumer electronic product, the price of a thing usually reflects the quality of that thing.
As for cleaning discs; if a laser has enough residue built up on it to prevent the error correction system from overcoming it, then the microfine brushes on a cleaning disc will probably be ineffective at removing that build up. Cleaning discs are akin to the old VCR cleaning tapes, usually ineffective.
Sorry for the bad news,
Rob
Posted on Jan 14, 2009
  • 114 Answers
SOURCE: I have a 32md357 magnavox tv. a dvd disk is stuck
Hello
Please try turning off the tv... wait about 30 seconds, PRESS AND HOLD THE EJECT BUTTON then turn the tv back on again. You can let up on the eject button as soon as it starts to spit out your dvd. This is a standard way to remove disks.
I hope this helps
Posted on Nov 27, 2010
How can I get the DVD out of the recorder, it's stuck?
Hi generally most dvd players have a small pin hole below the disk tray. It maybe covered by a dvd flap.
One you get to it just insert a pin and that will release the internal dvd player lock.
Thanks
Jul 28, 2017 | Magnavox MWR20V6 DVD Recorder VCR Combo
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
I have a Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo. But the DVD player shows some error. It said "playback feature may not be available on this disk" and it dosen't read the disk.
Try some other discs if you have not----If all show the same or similar error you have either a dirty or bad optical pickup in the player (it reads the discs).
Apr 25, 2012 | Philips Magnavox 20MC4304 20 in....
Universal remote code for Magnavox MWD7006
try 0503,or 0675 won of these two will work for sure,can,t remember which one i used though. got it from the the manual that came with my cox tv universal remote
Jun 02, 2009 | Philips Magnavox MWD7006 DVD Player
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd
Hi helen670,
I have two models to recomend, one is the Philips DVD R 357H/37 that has a hard disk for you to save TV shows and you can burn them later on CD's or DVD's, or you can burn them directly. It's around $290 and can also play any DVD or CD.
Another model is the Panasonic DMR-EZ27K that lack's of a hard disk, which makes it cheaper (around $200), but still can record CD's or DVD's directly from the TV.
Hope it helps.
Jul 12, 2008 | Philips Magnavox DVD/VCR Dual Player
I WANT TO CONNECT MAGNAVOX ZC352MW8 TO DVD/VCR COMBO AND TO TV TO RECORD VHS TAPES/DVDS AND TV PROGRAMS AS WELL
I just got a MAGNAVOX ZC352MW8 also. I did get it to record the TV, but I can't get other DVD players to read the disk although the ZC352MW8 reads if fine. I have no idea what is going on with this machine.
Jul 02, 2008 | Televison & Video
Phillps vcr/dvd player
I can't get the TV Stations to come through after we hooked it up the model number is DVP3345V/17
May 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
