Insert dvd, starts to spin up and stops, starts, stops, starts......and then is silent
I have the same problem. when i put in a disc while holding down the little button that makes it think it's closed, it starts to spin and if i keep on spinning it it will say loading until i stop spinning it, then it just says no disc.
Posted on Jul 17, 2008
No disc spin-up when inserted or when powering up
The problem is in the pladder motor that spins the DVD, the motor needs to be replaced, but the problem is they only sell the laser pickup assembly, which is very expensive.
Mar 13, 2012 | Samsung DVD-V8600 DVD Player/VCR
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
DVD-RW drive does not read disks
the DVD-RW is faulty, take it in and get another one to replace it. the clicking noise may be coming from the rack gear inside the device and causing a malfunction.
Sep 13, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
May 07, 2009 | Philips LX3900SA System
Dvd player on computer doesn't work.
i have a toshiba satellite. my d drive is not reconizing a cd or dvd when it is inserted. it just spins the stops. i have windows xp home ed.
Feb 18, 2009 | Computers & Internet
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
Audiovox D1020 DVD player
I opened up the dvd player & determined that the dvd was not spinning or took too long to start spinning, so the reader stopped. It looks like the arm that holds the dvd against the motor mount that turns it does not have enough strength to push against the dvd so that the motor mount does not spin without making the dvd spin with it.
For now, I'm using a small wooden prod inserted into the dvd slot to gently nudge the dvd to get it spinning. When the time comes that that doesn't work, I'll try to adjust the arm, but that's a last resort before I buy a new player.
Sep 18, 2008 | Audiovox D1020 Car DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
267 people viewed this question
Top Televison & Video Experts
Electro Med Services...
