Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard Dishwasher only starts when pressing start repeatidly
We have a 2.5 yr old Kenmore dishwasher which over the last 6 mo has been not starting at the first press of the start button. sometimes it takes standing there and pressing it 20 times before it starts - other times it starts on the first try. any ideas?
No personal experience with this machine, but two things come immediately to mind:
1. If the door latch is not quite closed then the machine still thinks it is open and thus will not start. Try gently pushing on the door as you push the start button. If no joy, then check to make sure that the latch mechanism (what can be seen of it - usually very little!) has no food deposits on it.
2. The start button contacts may be corroded. Try pushing the start button more firmly - and wiggle it at the same time.
Posted on Jul 16, 2008
How do I reset my panel for my kenmore precision dishwasher with quiet guard
Just hold the Start button for 3 seconds, and it should drain and shut down.
Sep 16, 2014 | Kenmore Dishwashers
My kenmorre quiet guard 2 dishwasher is not draining completely and is leaving dishes with a soapy residue.P,ease help.thank you.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
377 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
