Question about Canon PIXMA MP780 All-In-One InkJet Printer
Color off balance
Hello Gentlemen:
When I print or copy colors are all wrong- blue prints as purple, grey copies as red. Cartridges have been removed and replaced properly as well as completely replaced with new ones. Also have performed nozzle cleaning and deep clean several times. What is happening? Can't get to a place where printer maintenance will allow manual adjustments... Please advise. Thank you! :o)
  • 3 more comments
  • Anonymous Oct 02, 2008
    I have the same problem. Red is printing yellow and grey is printing green.
  • Anonymous Feb 04, 2009
    the same problem with mine.
  • L1nny Feb 11, 2009
    Blue prints as pale purple. Blue prints on nozzle checks but not on printout. Blue does not enter the mix so all colors off balance. Any answers...?
  • pmanthey66 Feb 12, 2009
    same problem
  • jondrea Feb 18, 2009
    My colors are off as well and the saturation is too high. Details get lost. I am phoning Canon next. If I get any answer I will come back and let you know what is going on.
I am going to try and explain this as best I can and hope it helps you all. I just did this on my Canon Pixma mx700 and printed a perfect photo when I was done.
Open control panel, go to printers and open that. Right click the printer you would like to adjust and click Properties. On the General tab there is button that says Printing Preferences. Click it. When it opens look to the middle where it says Color/Intensity. You have two options Auto or Manual. Check manual and then hit the set button to the right. New window opens with color adjustments, saturation etc. Now my issue was saturation and contrast. So I adjusted those sliders so the top picture matched the bottom picture on the right hand side of the box you are making the adjustments on. Adjust yours according to your needs!
I really hope this helps you all. Mine looks 100% better. Let me know if it works or not. Good luck!
Posted on Feb 18, 2009
Why is this EPSON STYLUS C88+ "Dura Brite Ultra" printer printing the wrong colors?
You have a corrupt or incorrect printer driver. Completely remove all references to the current driver from the computer. Un installing is not enough as the registry references remain. Then install the driver(s) again.
Jul 22, 2014 | Epson Stylus C88 InkJet Photo Printer
Not printing color correctly
try disconnecting the printer from your computer then uninstall the printer and reinstal it again the reconnect the cord from the printer to the computer and try that
Feb 26, 2014 | Xerox Laser All-In-One Machines 6505/N...
Can't print colour copies with HP d1470
Check color cartridge good?Go to printer properties > preference>color>remove check mark in print in grey scale.. check for color print..
Dec 22, 2011 | HP Deskjet D1341 InkJet Printer
I have recently bought new ink for my brother mfc 255cw. While it was running low ink, it would print out copies colored purple. even though I have already purchased and replaced all the ink cartridges, it...
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Office Equipment & Supplies
Ref.: BJC 620 I cannot get true black print, instead I get sort of greenish color where the black shoud be.
Hello, look at what cartridges are being used and what is status indication? There are several things to think about, as follows:
1) Is there a good black cartridge? Many color ink-jet printers will print black using color cartridges if black is out, low, or bad.
2) Can you use a standalone copy mode - if possible for your printer -and get good/correct copy colors (not using the computer)?
2) Have any cartridges been refilled manually? I have done this where I thought I refilled a cartridge with the right color and filled it with the wrong one by accident -oops. Please try different cartridges.
3) Is your printer color problem the same when using any or all programs? If it is and you are sure all the cartridges are OK then use your printer software to reset all the settings to a default factory settings and try again.
Oct 30, 2009 | Canon Office Equipment & Supplies
Printing in wrong colors
You need to go to the maintenance tab on your printer properties and deep clean the head. If that fails, remove the print cartridges and poor some rubbing alcohol on the print head enough to wet it, replace cartridges and deep clean again, if that fails you may need a new print head or replace the printer, cost dependent.
Oct 08, 2009 | HP Photosmart 3310 Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
May 08, 2009 | HP PSC 2110 Color Printer
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
164 people viewed this question
old marine
old marine
