Question about Texas Instruments TI-89 Calculator
Can't input values for xres in graph window.
You know when you're setting the parameters for the windows to graph.  You can go with the pre sets ala trig, standard, you can zoom in and out, all that stuff.
But when you hit 2nd, then F2 for window, and it lets you personally input the values, I can do all but xres, all the way at the bottom.  It's fuzzed out, similiar to the way after hitting F5 on the home screen, all the other "F"'s get fuzzed out.
  • Anonymous Sep 24, 2008
    I can't input any value on xres. I can put a number on everything else i.e. xmin, xmax, etc. How do I fix this??
  • Anonymous Oct 22, 2008
    It's grayed out...what can I do?
Go to the graph app (diamond + f3)
to the graph apps settings (f1 , then 9: Format)
turn off discontinuity detection
go to the window setupt (diamond + f2)
change xres to 2.0
Posted on Mar 12, 2009
Http://epsstore.ti.com/OA_HTML/csksxvm.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZGD1F177B99C79B371AE500C722AB34CC063F90DAC78E6E98D0A0A483E311F5FEB68AD612D8E201010B9B600867E67F6059B&nSetId=85575&nBrowseCategoryId=10503&cskViewSolSourcePage=cskmbasicsrch.jsp%3FcategoryId%3D10503%26fRange%3Dnull%26fStartRow%3D0%26fSortBy%3D2%26fSortByOrder%3D1
Posted on Jan 23, 2009
How do you change the interval for a arc cos
I'm not sure of the question, but to plot arccos set mode to: graph='function' and angle to 'degrees' (for example). Go to WINDOW and set xmin=-1, xmax=1, xscl=0.1, ymin=0, ymax=180, yscl=50, and xres=1. Press GRAPH. You will get a plot of arccos from -1 to 1.
Mar 31, 2014 | Texas Instruments TI-89 Calculator
Today i was trying to graph y=2x+23, but when ever i would press graph it would pop up window variables domain. What do i do to fix this?
Your ranges for your window settings are more, or less out of bounds with the equation y=2x+23, that you entered.
Press the [green diamond], and the [F2] keys to bring up the graphing coordinates. Enter the following values to fix the graphing coordinates. Starting at the top, xmin= -8, xmax= 8, xscl=1, ymin=0, ymax=40, yscl=1, xres=2. Now, press the [green diamond], and the [F3] keys, and the graph should display.
Dec 18, 2010 | Texas Instruments TI-89 Calculator
How do i fix the window numbers on my calculator
You can try to reset the calculator: In so doing the default configuration is restored. If that works for your graphs why fiddle with the setting?
Ok to reset calculator (do not worry I will tell you how to change window dimension):
Press [2nd][+] to access the (MEM)ory management.
Press [7:Reset][2:Defaults] [2:Reset]
The window dimension will be restored.
To change dimensions
In main calculator screen press the [WINDOW] function key
Enter the value of Xmin. If negative use the change sign key (-) under key 3
Enter Xmax value. Make sure that Xmin is less than Xmax.
Leave the Xscale at 1
Enter Ymin. If negative use the change (-) key
You can leave the Yscale at 1, Xres at 1.
You can change the DeltaX but if you take too small a value your graphs will take long to be drawn.
If you ever get a problem, just press the [ZOOM] function key and select [6:ZStandard] it will restore the default dimensions.
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
ERR: Window Range
Press ZOOM and select Zoom standard (ZoomStd).
Alternatively, press the WINDOW key to access the window range setup
Set Xmin=-10
Xmax=10
Ymin=-10
Ymax=10
These are the standard dimensions of the window.
You can change the dimensions as long as Xmin is less then Xmax, and Ymin is less than Ymax. Do not make Xres close to Xmax-Xmin.
Jan 10, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
Nov 11, 2009 | Office Equipment & Supplies
What numbers should the window key have
Xmin is the smallest value of variable X: by default it is -10.
Xmax is the largest value of variable X: by default it is 10.
Ymin is the smallest value of Y default is -10.
Ymax is the largest value of Y default is 10.
You set these values according to the area of the graph you want to see.
If X is always positive, you can set Xmin=0.
If function values are laways positive, eg y=x^2, Ymin=0.
Xscl =1 by default. There will be a tick mark on the X-axis for each X integer.
YScal=1: there will be a tick mark for each integer value of y. If you want tick marks every 0.5 you set Yscal=0.5
Xres=1. Calculator calculates y values say at X, X+1, X+2, etc.
Hope it helps.
Sep 24, 2009 | Texas Instruments TI-83 Plus Calculator
How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Problem using graphing on my casio
This calculator has so many options you can change, that it is possible one of them has been altered. Try pressing the master reset button at the back to re-set the calculator. Note that you will lose all your programs and data, so first copy out anything important. Also, set the xmin and xmax parameters to a higher value. To plot a sign wave, try xmin=-720, xmax=720, step=1, ymin=-1, ymax=1, step=.1 The step value won't change the appearance of the graph, just make it more chunky or fine. Use the equation y=sin x. This should draw a sign wave showing 4 complete waves. PS when you enter the X in the equations, you are pressing the X,0,T button, the one under the alpha key, aren't you? If you enter X using the x alpha key, it won't work. Also, to plot y=, make sure you change the func type parameter in the Set Up menu to y=. Hope this helps.
Oct 11, 2008 | Casio FX-9750GPlus Calculator
TI-82 graphing problem
You must press 2nd then "zoom", then go down to axes, and turn them on. Now your graph will work again.
Jan 29, 2007 | Texas Instruments TI-82 Calculator
Texas Instruments TI-89 Calculator Logo
585 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
