Question about Singer 7442 Mechanical Sewing Machine
Singer advance 7422
My Singer Advance 7422 will not continue to pick up the bobbin thread after the first few stiches. The manual that came with the machine does not have any infromation on the bobbin except that the tension was set at the factory and should not need adjustments.
  • Anonymous Aug 15, 2008
    the bobbin is out of time with the needle............
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Posted on Mar 21, 2011
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Top thread will not pick up bobbin thread on my model 7422
try a new needle--make sure it's the right needle for the fabric
being sewed.
try rethreading the machine top and bobbin --make sure to use
every thread guide
try a different bobbin
it's also possible that the machine could have a timing problem
and needs to be checked
here's a free manual if you need one just click on the link
http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf
Dec 06, 2012 | Singer 7422
Singer advance 7422 beeps when i am trying to sew
are you getting a visual signal on your LED display ?
have you tried turning the machine off & waiting a few seconds & turning it back on again
have you tried cleaning the bobbin area for loose threads & lint?
how many beeps are there?
do you have a instruction manual for the machine? if not singer has one for free pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422 ) & click search
Feb 01, 2012 | Singer 7422
I have a singer advance #7422 sewing machine. The needle will not pick up the thread from thr bobbin although I know I have the bobbin in corectly. Can you help me with this?
You may have the needle in wrong. Check to be sure it's positioned correctly, The groove down the center of the needle should face the front of the machine. And be certain the needle is pushed completely up in its holder. If neither of these work, you might just double check the bobbin!
Nov 09, 2010 | SINGER 7470 Sewing Machine
My Singer Advance 7422 skips stitches intermittently. Looks like it does not pick up the bobbin thread sometimes. Any suggestions?
Change to a new needle appropriate for the fabric you will be sewing. Make sure the flat side of the needle shank faces to the back of the sewing machine.
Always thread the machine with the presser foot up as this will "seat" the thread into the tension control.
Mar 17, 2010 | Singer 7442 Mechanical Sewing Machine
The thread tension on my singer advance 7422 is to loose, and i move the thread tension dial to make it tighter but it doesnt make a difference. what can i do to fix this?
Useful to check the spool and bobbin threading. If either is not threaded correctly, the fabric will pucker/thread will break/loops will appear on either side of the fabric. Easiest to do with machine manual open so as to follow the instructions. Easiest to check your threading each time you change threads by running a test seam on scrap fabric (I keep a large piece of scrap fabric folded in half just for this). More often than not, the problem is with threading. Check threading before you change tension dial or ajust screws. Otherwise, you'll have changed the tension and may still have threading problems. Good luck.
Oct 16, 2008 | Singer 7422
Singer 7442 Mechanical Sewing Machine Logo
425 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
