Question about E-Machines eMachines Desktop PC
E-machine 5220 power up
Blue back light around on/off button flickers as well as green power light ( as if a switch is not latching - if that makes sense ! ) needless to say , pc dont work
  • hizzy34 Sep 22, 2008
    I have the exact same problem power light flickers around switch and HDD light is constant too. fans run ok, but it doesn't boot up. I want to know if there is a replacement motherboard for my emachine 5220.
  • 26 Answers
Emachines have notoriously cheap power supplies. Often, while the power supply itself doesn't fail, it causes the failure of motherboard components, essentially trashing the computer.
Try the following:
First check and make absolutely certain that the power switch connector is properly connected to the motherboard. (Take standard grounding/safety precautions: wear a properly-grounded grounding strap, for example, when working with any internal components.)
Obtain a known-good power supply of equal or greater capacity to your eMachines PS and switch 'em out.
If either of these fixes your problem, well and good. If not, the problem may be, as is all too common with eMachines power issues, a motherboard issue caused by the power supply.
Posted on Jul 17, 2008
What is bluetooth for?
    • Connect a Bluetooth audio device (Windows 10)
    • Miracast wireless displays
    • WiGig wireless displays
    To connect your Bluetooth headset, speaker, or headphones to your Windows 10 PC, you'll need to pair the device first.
    1. Turn on your Bluetooth device and make it discoverable. The way you make it discoverable depends on the device. Check the device info or website to find out more.
    2. On the taskbar, select the action center icon and make sure Bluetooth is turned on.
    3. In action center, select Connect, then pick your device.
    4. Follow any additional instructions. Otherwise, you're done.
Nov 16, 2016 | Computers & Internet
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
How do i turn my bluetooth on?acer aspire 5044wlmi
For Acep Aspire 504x model systems that have Bluetooth built in, there is an on/off switch located in the front of the system.
For systems with bluetooth built in there will be two buttons next to each other just left of the mic and headphone ports.
The left of the 2 buttons is the bluetooth switch and the right of the 2 buttons is for 802.11 wireless.
If you only have 1 button then you do not have bluetooth built-in. You can also check to see if bluetooth is included by looking at the bottom, if Bluetooth is installed there will be a white FCC lebel with the name Bluetooth written on it.
Nov 18, 2009 | Computers & Internet
How do i turn on the bluetooth on my netbook msi
Is it equipped with bluetooth? Do a search for bluetooth on your computer and it should bring up the bluetooth icon. Go "start", "search", then "all files", and type in bluetooth and search.
Oct 29, 2009 | MSI U100-422CA Notebook
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
E-Machines eMachines Desktop PC Logo
113 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
