The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Thanks Lumpy816. This did help. I just didn't know where to look for the codes. The F9 code deals with pressure in the pump. I cleaned out the pump filter and all is well.
Thanks again
I don't know F9 off the top of my head, but if you remove the lower front panel (3 #20 torx screws along the bottom edge of the panel) There is a plastic envelope inside that has a tech manula with all of the error codes and explinations listed.
Thank you Toby, I found the tech manual exactly where you said. Very helpful.
