Surround sound speakers
I have a Kenwood mini stereo system for which I want to buy surround sound speakers. Kenwood advised that I need two RMS-70 watt speakers at 6 ohms. The original speakers have a maximum input of 100 watts. Could you advise a selection of speakers which might work? THanks.
  • 682 Answers
Two rms-70 watt are good enough for you.
Posted on Jul 23, 2008
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
KENWOOD KR-V8030 SPECS
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Feb 19, 2012 | Audio Players & Recorders
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
No user manual
All speaker cables go into the surround sound system, they should be colour coded, then phono cables into the TV or just the the normal green audio cable into the green audio hole on the computer
Feb 18, 2009 | Durabrand 5.1 Surround Sound Computer...
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
My kenwood receiver has
If you are referring to the rear speakers, it is normal. The rear speakers are not supposed to get a signal as loud as the fronts or center.
A surround sound system was originally developed for playing movies and the rear channels are for effects. In most surround modes the center channel will always be the loudest with the widest range of audio signals.
I have been repairing these type of systems since they have been on the market, so I know a lot about them.
This Kenwood you have is like most surround systems and does not have a feature that you would obviously like to have, 5 channel stereo. Only a few surround systems have this feature and they cost much more than the Kenwood systems. Denon and Marantz both make one with that feature. In 5 channel stereo you get a full signal to all the speakers. All the other surround modes you get a much lower signal to the rear speakers.
So in closing, you do not need it fixed, there is nothing wrong with it. You have a common complaint that many people have who buy a surround sound system but are not fully understanding of just what a surround systems is supposed to be capable of
. This is something that the salesman who sold it to you should have explained to you, that way you could have purchased a system that would have better suited your needs.
I would be happy to give you more help if you would like, just let me know. As I already stated, I have many years of experience with surround sounds systems, in fact I own the exact Kenwood model that you have and I like it very much. It is about the best you can get for that price.
Dave
Aug 22, 2008 | Kenwood VR-505 Receiver
95 people viewed this question
 Grubhead
Grubhead
