Question about Epson LX-300 Matrix Printer
PRINTER PROBLEMS TRYING TO PUT THE PRINTER ON CONTINUOUS FEED BUT THE LIGHTS THAT ARE UNDER TEAR OUT (2 GREEN LIGHTS SIDE BY SIDE) KEEP BLINKING. THEN THE PAUSE/ PAPER OUT LIGHTS (ONE RED, ONE ORANGE) ALSO KEEPS BLINKING. pAPER WONT AUTOMATICALLY FEED CONTINOUSLY. THE ONLY WAY TO FEED THE PAPER IS BY TURNING THE FEED KNOB MANUALLY WHICH IS LOCATED ON THE SIDE OF THE PRINTER. EVEN AFTER DOING SO, THE PRINTER STILL WON'T PRINT THE INFORMATION!
  • joseph irvin Cardama
    joseph irvin Cardama Oct 29, 2015
    HELLO SIR, CAN GIVE ME THE ANSWER ON THIS PROBLEM..SEND SOME TIPS TO MY EMAIL ADD: jcardama07@gmail.com
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Posted on Jul 17, 2008
PRINTER PROBLEMS 2 GREEN LIGHTS SIDE BY SIDE KEEP BLINKING. THEN THE PAUSE/ PAPER OUT LIGHTS ONE RED, ONE ORANGE ALSO KEEPS BLINKING. pAPER WONT AUTOMATICALLY FEED
There are several reasons for this problem. One is the paper tray is either too full or not closed properly. There is a sensor and if the sensor is faulty the same symptoms happen. It happened to me sometime back. How old is your printer? If it is within the guarantee period you should take it to the dealer and he will have to either repair or replace it.
Oct 29, 2015 | Epson LX-300+ II Matrix Printer
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
HOT TO ADJUST THE TEAR HEIGHT ON A MICROLINE 490 WITHOUT USING THE SETUP DISC
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
Ink Absorber full,needs changing.How do I Change
You need to disassembling the hole printer to find and replace the ink absorber.It's on the bottom from right side under the pump station.
Also you need to reset the ink counter:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma ip1300 Ink absorber is saying is full what is the easiest way to solve this problem
open printer. with gloves or unless you don't mind getting your hands dirty, Open top of printer lid, carefully, pull out spongey grey piece at bottom of printer. to your left side is a piece of plastic, pull that off and below it is another sponge. Carefully pull this out as well. Wash and squeeze excess water. replace. YOU MAY WANT TO USE A FLASHLIGHT TO BE SURE YOU CAN SEE WHAT YOU ARE DOING. UNplug printer, hold button. restart, release button - as described above. Keep trying. Then do a bottom plate cleaning. keep trying eventually everything resets and you can continue working. To remove ink from hands and plastic, use alcohol.
then you will need to reset it this works on some canon printers not all
1. Turn off printer
8. Your printer should respond as normal..
Good luck
Jul 21, 2009 | Office Equipment & Supplies
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Cant print. the tear like button is blinking
I have a 6940 color printer and I am assuming the 'tear' buttons are the same. If so, it is an out of toner indicator.
Dec 05, 2008 | HP DeskJet 5650 InkJet Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Epson LX-300 Matrix Printer Logo
690 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
