Question about ViewSonic N3251w 32 in. LCD HDTV
Powerlock Enable I have a N2060w LCD TV and have a problem with the unit, for a couple of weeks now where the TV will not turn off using the power button on the unit or the remote. Along with this the message "PowerLock Enable" is displayed in the right middle of the screen i have used a support site on which it said that to take this off was to hold both the [1] button and either up or down buttons together for 10 seconds. i have tried this but it has not worked. i took [1] to means the on/off button. could you tell me what to do to get this problem fixed. How do i turn offpowerlock enable?
There are buttons on the bottom of the monitor. Counting from the left, hold down buttons 2 and 3 simultaneously and this will disable the power lock feature. At least that's what I have to do on my 19" model ViewSonic.
Posted on Jan 01, 2010
Viewsonic N2060w no picture but sound My Viewsonic was working fine yesterday, now when i Turn on there is power going to the TV but no picture on the screen?
LCD backlight has gone out , you can verify this by holding a flash light up to the scene to see image , www.partstore.com or www.shopjimy.com where you can buy the part and put it in yourself would save you money
Oct 04, 2011 | ViewSonic N2060w 20 in. LCD Television
Can be related to a possible fault in the inverter board , failure of the back light . Please check the power to the board and check the back light circuit.
I have a Viewsonic N2060w-1M TV but I don't have a remote. How to I program a universal remote control - Jenses -to work with my Viewsonic?
For the remote codes, Viewsonic does not have any since the universal remote comes furnished with a code book from the "MAKER" of that Universal Remote. I have heard that the Philips TV brand codes for universal remotes work on quite a few series' of Viewsonic TV's, so try those from your code book.
May 30, 2010 | ViewSonic N2060w 20 in. LCD Television
Powerlock Enable cannot be removed from my ViewSonic N3246w.
I have a 19" ViewSonic and if you hold down the 2nd and 3rd buttons together under the screen, counting from the LEFT, it will disable the Powerlock.
Aug 31, 2009 | ViewSonic N2060w 20 in. LCD Television
Sky code
Sky remote codes: 0805 1783 1785.
Here are some other codes that may work with the Viewsonic: 1295 1694 1697 1800
Aug 27, 2008 | ViewSonic N2060w 20 in. LCD Television
Power lock enable
To get rid of the power button enable you need to either press and hold the power button on the tv ( not on the remote control pad) for approx 15 seconds or if that does not work do the same using the source button
Jun 03, 2008 | ViewSonic N2060w 20 in. LCD Television
Powerlock Enable
Hi.
Nice easy one to put right do this.
PRESS AND HOLD THE SOURCE BUTTON FOR 20 SECONDS.
This will remove the lock.
http://dysonmanuals.llc.nu/
Chris..
Jan 22, 2008 | ViewSonic N2060w 20 in. LCD Television
Ps3 trouble
ok, i got it working... Ok...your problem is probably that when you're using it on the HDTV...you have the resolution set to an HD one (720p, 1080i, 1080P). A normal TV cannot display these. While it's connected to the HDTV,Before you connect it to your normal tv, you have to switch it back to 480i or 480p otherwise, your regular tv wont show a picture. So go to settings, display settings, and uncheck 720p, 1080i, 1080p. It will ask you if these are the settings you choose (and it's going to look funny on your HDTV) Accept the settings and turn it off. When you connect it to your Regular TV, you should now see a picture. Hope this helps!
Dec 13, 2007 | ViewSonic N2060w 20 in. LCD Television
Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
Dec 05, 2007 | ViewSonic N2060w 20 in. LCD Television
ViewSonic N3251w 32 in. LCD HDTV Logo
282 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
