Question about Brother IntelliFAX 2800 Laser Fax
WHITE STREAK (NO TONER APPLIED) ON LEFT SIDE OF INCOMING FAXES
CAN YOU SUGGEST A SOLUTION FOR THE ABOVE? WE HAVE PURCHASED A NEW DRUM AND INSTALLED IT AND REPLACED THE TONER CARTRIDGE - STILL HAVE PROBLEM...
KIMMOORE500@YAHOO.COM
THANKS SO MUCH!
  • stubbe Jan 08, 2009
    I have cleaned the glass bar, and it does not take off the white streak on the left side of the "incoming" faxes.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
You did not specify if sending or RX
open the part where you insert the papers to fax out (this is also in the troubleshooting of hte manual) look at the strip of glass is there anything on it?
Open the machine, remove toner and look at the strip on bottom of machine clean.
http://safemanuals.com/index_google.php?cx=partner-pub-1682016597802119%3Axo3rw7s1srj&cof=FORID%3A10&q=brother+2800+manual#0
Posted on Jul 18, 2008
Hp laserjet 3200
take printer outside of building
pull out toner cartridge and drum carerfully
Spray inside of printer to get rid of split extra toner with a can of compressed air - usually available from an electronic supply shops
Check the drum has no tone split on it .
Put drum and toner cartridge back into the printer
Jan 26, 2018 | HP LaserJet Office Equipment & Supplies
I have a blank line running down the left side of all my faxes and copies. I have changed the toner and installed a new drum. Still having the problem.
You most likely have toner on the roller, which should be just above or below the drum, clean this by spraying some window cleaner on a paper towel, or lintless rag, and rubbing the roller clean, make sure to get all foreign particles of roller before closing and trying to print.
Oct 14, 2010 | Brother IntelliFax-2820 Laser Fax
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Vertical Streak on my sent faxes
Open up the document feeder and clean the scanner glass. If the streak is larger than 1/4 " wide, you have a bad scanner block.
Apr 23, 2010 | Brother IntelliFAX 4100 Laser Fax
Dark band on left hand side of incoming faxes
Your toner cartridge is leaking toner onto the transfer roller. There is no cure except for replacing the cartridge.
Dec 10, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Just replaced drum and toner and now faxes don'y
if your toner and drum have been at an angle , toner will only be on the left side.
here's the fix.  Remove drum cartridgewith toner in it and move it gently from extreme right to extreme left, do this three times and your image should be ok
Aug 13, 2009 | OKIFAX 2600 Fax
Brother intellifax 2820.Replaced toner cart tn350.
Remove drum unit. in front of the toner cart. there is ether a green or blue slide lever. move the slide 10-15 times back and forth. make sher the slide is all the way over to one side. reinstall drum & make a copie. hope this works.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Drum has 13% life left; white paper w streak in middle when you copy
Try taking out the cartidge and given it a light shake. If the white streak moves or changes then you are out of toner.
As for sending faxes, do you get an error message an any kind? Does it try to dial?
Jan 11, 2008 | Brother MFC 8500 All-In-One Laser Printer
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Brother IntelliFAX 2800 Laser Fax Logo
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
