Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire Electric Range error code
I get an error code of F30 when I try to turn on my oven or convection oven. The ceramic range top works fine. My range model number is PLES389ECD.
  • 1 more comment
  • Anonymous Aug 16, 2008
    Same thing here. Please Help
  • Anonymous Oct 19, 2008
    I have the same problem my stove is continously beeping with a F-30. Do I need to call a repairman? Shan, Georgia
  • Anonymous Mar 28, 2014
    oven will not come on. is there a way to bring up errors
  • 116 Answers
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 639 Answers
Hi jacksmdmat,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
My frigidaire does not heat consistently. F10 fault goes off if it's on for a couple of hours or if we broil. F10 also goes off after cleaning during cool down. F30 goes off after oven is turned off. ...
Good Morning Irene, thank you for allowing me to assist you!
The F10 and F30 error codes are in regards to an open or failed oven sensor. If the sensor and EOC has been replaced, more than likely a professional would need to inspect the wiring harness between the EOC and sensor.
Best regards!
Oct 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Oven will not come on
There is a oven controller on those type ovens and if you cannot get your oven to heat up but the stove top still works it is because there are on different circuits and the cotroller will cost near $350 if you have a convection oven and twice that for a service person to install!!
Sep 11, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Oct 07, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Need help with error code for Frigidaire Oven Please!
Hi thanks for the question. the code f 2 means the oven sensor has failed .the sensor is located in the oven, top left corner. replace the sensor. thanks the appliance doc.
Jan 12, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
3,462 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
