Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
KP-51WS510 Where do I locate the RED CRT on my Sony TV
  • 2,326 Answers
If you are facing the front of your TV, the red CRT is on your left. To get access to remove the CRT assembly, you will need to remove the speakers cover and one more wood or plastic cover that is protecting the CRTs.
Posted on Jul 17, 2008
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510
I would suggest to turn the screen control potentiometer down a bit, this control is found on the front of your TV nearby the CRTs.
The part looks similar to the picture. Click here to see picture.
The red control is the one on the left if you are facing it.
Let me know if you need further assistance.
Jul 30, 2008 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510
You do not need to replace the CRTs(picture tubes) just the assembly that is connected to the red CRT, or just the IC7101, with markings TDA6120Q.
I would suggest to put fresh solder on the IC leads first since the TV only becames red after is ON for a short while.
Click here to find the entire assembly for your TV.
Jul 15, 2008 | Sony KP-51WS510 51" Rear Projection...
No Picture / TV screen RED
There seems to be a dry solder joint on the video amplifier IC. The red picture is cause by a defective video amplifier IC(IC701) that is located on the red CRT assembly.
This repair might not be a DIY due to the danger of working around devices that produce high voltages in excess of 32KV.
Sony color TV screen
Your green CRT socket may have a solder crack, or it could be the CRT developing a short. You can switch the green CRT socket with the one from the red RT and see if it still flashes green. If it does then its your CRT, But if it now flashes Red, Its a problem in the green drive circuitry.Thts the quickest way to locate exactly where your trouble is. If you need anything further let me know.
Jan 25, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Television
If model # is KP-46S25, red CRT is probably bad...have it checked by a qualified Sony tech......................T.
Jan 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
