Question about Dell Dimension 4600 PC Desktop
Monitor and Mouse not working
I have a Dell Dimension 4600 Desktop. Yesterday I turned on the computer and it started to boot up but the busy light to show it is working didn't come on and my monitor light went from green to amber right away. I tried moving the mouse but that didn't respond either. I plugged them into another computer that we have and they worked. The computer just went out of warranty. It is three years old.
  • 1 more comment
  • Lynn Saville Jul 17, 2008
    The LED's are: green, green, green, amber then it turned green. I also replaced the battery and that semed to help but the computer is running rather slowly now.
  • Hevyman May 11, 2010
    Can you boot it to Safe Mode?
    1. turn on computer while hitting the F8 button
    2. Select Safe mode with networking
    Does it come up now?
  • IQUIT May 11, 2010
    on the back of the tower are 4 LEDs marks ABCD just above the PS2 ports, what sequence to they indicate Green Green Green Green? or some combination of green and amber?
    Post the displayed sequence, and I can assist you in determining the failure.
    Sergeant:
    Champion:
  • 275 Answers
Reseat the memory cards buddy
Posted on Oct 31, 2008
  • 3,940 Answers
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
Posted on Jul 18, 2008
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 monitor has gone completely black though it shows it booting.
Start your computer in "Safe Mode".
Change the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, and restart.
If you eventually see your "wallpaper", try setting your screen-resolution to 1024 by 768, and "test" it. If OK, try setting your screen-resolution to 1280 by 1024, and 'test" it.
Jan 07, 2010 | Dell Dimension 4600 PC Desktop
Turning the pc on
try changing your graphic card ( VGA Card ) .. if the problem keeps coming then try the monitor on another computer .. if it works then you have problem with RAM drives
Dec 25, 2007 | Dell Dimension 4600 PC Desktop
Filmstrips
Sounds like a corrupted video driver.
Have her do a system restore.
Then get an updated driver off Dells Support pages..
Nov 15, 2007 | Dell Dimension 4600 PC Desktop
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
209 people viewed this question
Alun Cox
