Question about Maytag MDE2600 Electric Dryer
Replacing timer switch
My replacement timer switch arrived yesterday so I'm now ready to replace the defective timer switch on our Maytag MDE2600 electric dryer. What is the proper way to get access to the timer switch to remove and replace it? Is it nothing more than disconnect power and remove the four screws on the back of the panel?
Thanks, Ken.
  • Anonymous Mar 20, 2014
    How to replace defective door switch on Maytag dryer
Maytag dryer/ will not stop runing
Posted on Jan 06, 2009
  • 246 Answers
If you are replacing the timer, after you unplug it, first pop the plastic cap off the knob of the timer. Underneath you will find a small clip on the timer shaft that holds the knob on and makes it imposible to get the timer out without daming the know. Use a small flat head screwdriver to slide the clip to the side. Now you can remove the rest of the knob and the screws holding the timer in place. Next remove the screws along the top of the console. Push forward on the bottom of the console while gently pulling the top towards you. You will now see your timer laying there. Release the catch on the connector that holds all of the wirse to the timer. Reverse the process for instalation.
Posted on Jul 17, 2008
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
Will not start. Checked pwr to the plug. Is there a reset button? It worked just fine yesterday. Door latch is clean and tight.
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 16, 2009 | Maytag MDB6000 Dishwasher
My dyrer doesn't turn on. It just stop working.
Check the following to address this issue.
No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Timer
Jun 06, 2009 | Maytag MDE2600 Electric Dryer
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
MAYTAG MDB4651A
This is most likely a problem with the timer.
The timer switch rotates and changes the operations that your machine executes.
It is probably the timer motor that is defective. Sometimes they can be replaced by themselves. Sometimes you must replace the whole assy.
If you need more help, post a comment and I will reply
Apr 26, 2009 | Maytag 24 in. MDB4651A Built-in Dishwasher
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
No power to control panel after power surge
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
3. Timer
4. Selector switch
Jan 05, 2008 | Maytag MDB7100AWB Dishwasher
Maytag MDE2600 Electric Dryer Logo
207 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
