Question about Epson Stylus CX3200 All-In-One InkJet Printer
Language cant change language on printer
  • joe builder May 17, 2009
    need to change language on epson dx7450printer
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Posted on Jan 05, 2009
    Genius:
  • 1,447 Answers
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Posted on Jul 16, 2008
How do I change the language of all Canon MP490 inkjet printer programs?
its on the menu-device setting-language
or you cant understand the language just follow this steps
1. first click MENU its on the upper right side icon.
2. press the arrow up once then press ok.
3. press down 8 times.
4. then you can see the language menu, select what language you want.
Mar 24, 2011 | Canon MP490 InkJet Printer
How do you change the language to english on the Lexmark X5250?..Its in another language so I cant change it because I dont know what im pressing.
1 Press the POWER button to turn on the All-In-One
2 Press and hold both the POWER and CANCEL buttons for 10 seconds.
Language text then appears on the display.
3 Press the BLACK COPY button repeatedly until the language you want appears on the display.
4 Press the ARROW button to select that language.
Thats it!
Mar 08, 2011 | Lexmark X5250 All-In-One InkJet Printer
How do u change the language on the fax machine
Press the power button for 4 seconds. That will turn off the printer. Now, press and hold Start and Back button (looping arrow) while turning on the printer by pressing the power button again. Continue to hold the Start and Back buttons for approximately 20 seconds, then release them. That should reset the printer. Choose your preferred language and set time and date.
Jul 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
How do i change language back to english from spanish
taking a guess at this but push the menu button once.. then the down arrow 5 or 6 times. and select it should bring you into the language menu and just click enter/ok. This should change it back to english.
Jun 30, 2010 | Canon MultiPASS MP370 All-In-One InkJet...
Different language..
best thing to do is uninstall all printer software then reinstall it and choose your preferd language
dont worry it wont affedct your computer or printer in anyway
Sep 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I need to change the language settings on my printer but because uts in a foreign language at the moment (I think its in greek) I cant change it.
Press the * and # button together and release them. the display will now show '**************#########'. now press the 1, 2, and 3 buttons one after the other. Then it'll show 'Support' and the firmware version. Next press the Right arrow button twice so you see 'Resets Menu'. Press the OK button. Press the OK button again when it shows 'Country/Language Reset'. The printer will now shut down. Turn it on again, and you can select the correct language and country.
May 03, 2009 | HP J4680 Office Jet All-In-One Printer
Changing language from french to english
http://safemanuals.com/zearchres_134.php this site allows you to get the manual for the machine this should help,
Jan 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Language problem
right click on the task bar goto toolbars in that select language bar .then after getting that toolbar in ur taskbar by clicking on that u can select the required language from the displayed list
Nov 30, 2008 | HP LaserJet 3030 All-In-One Printer
Magicolor 2300 language
hit menu, press the side arrow ( either side) it will cycle through the languages , when it comes to english... might read like Angalish.. leave it . hit select and your done , wait a few min before hitting menu again.
Sep 18, 2008 | Konica Minolta magicolor 2300DL Laser...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
