Question about Kenmore 11206 / 11306 / 11506 / 11606
Handwheel does not disengage from needle when pulled out (11206 model)
Brand new out of box. Works fine. But I cannot disengage needle by popping out hand wheel, in order to wind bobbin.
  • Kenmore Master
  • 1,388 Answers
Phone the shop where you bought it and arrange to take it back...this should not happen to a new machine....and if it is something you are doing, they will be able to advise you, if it is the machine, they will sort it out under warantee.
Posted on Jul 18, 2008
Kenmore 19233 sewing machine. Then handwheel is broken, spins freely. Machine works perfectly otherwise. How do I remove the handwheel and replace it.
If the drive belt is not off or broken, then check hand-wheel setting. On some models the hand wheel can be pushed in (to engage) and pulled out (to disengage) for using bobbin winder. If it is disengaged the hand-wheel will spin freely. On older models there is a smaller wheel that has to be hand tightened in order to engage rest of machine. Hope this helps.
Nov 20, 2016 | Kenmore Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
How to remove front casing from innovis 4000 brother sewing machine
I would contact Brother, they have an outstanding service department. But if the thread is only around the hand wheel, try pulling it outward to see if you can access the thread that way. Many hand wheels pop out, to disengage the needle mechanism so you can wind a bobbin.
Jul 17, 2014 | Brother Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
Have a singer 3221/3232 cannot disengage handwheel to fill bobbin what am I doing wrong
Are you sure you have to pull or push? It looks to me like you just slide the bobbin winder spindle to the right to engage.
Here's a manual for your machine... I'm sure more specific info is in there.
http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf
Nov 08, 2012 | Singer 2263 Mechanical Sewing Machine
Model no. 158.17741. the belt is moving, the motor is running, but the part that goes up and down with the thread is not, the belt seems to be tight enough
Check the centre of the handwheel, there will either be A) an inner wheel or B) push/pull device to disengage the needle arm when bobbin winding....it needs to be A) tight, or B) pressed in to re-engage the clutch for sewing......your manual will probably have a diagram,
I could not find a picture of this model, so unsure of the exact mechanism, but it is in the middle of the handwheel
Mar 11, 2011 | Kenmore Sewing Machines
Threading the bobbin, disengage the needle
Depending what brand and model of sewing machine it is, you can usually disengage the needle bar with the knob inside the handwheel by turning it towards you. If you've done that and the needle bar still moves, it needs oil and should be serviced by a technician.
Feb 24, 2010 | Sewing Machines
How to thread upper bobbin on Kenmore 11206
WAY OLD BUT .....slide the bobbin spindle from the left to the right and pull the handwheel out. YOU NEED TO DO BOTH. I never saw this til today hope its not too late!
Bonnie
Mar 19, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Needle wont go up or down
If the Handwheel (big knob) is moving but the needle is not moving, you need to engage the clutch ........depending on the model
- push handwheel in to engage, pull out to disengage
or
- if there is a smaller wheel inside the handwheel, tighten to engage, loosen to release.
BUT if all is jammed........
Check for threads that are jamming the motion of the hook around where the bobbin case is
If your bobbin goes in from the top, remove the needleplate and bobbincase remove thread jams by gently rocking handwheel back and forth until released.
Clean around the hook race with a rag moistened with methylated spirit, surgical spirit or similar, then reassemble.
If front loading, open the door for bobbin case area, release 2 retaining clips holding the collar on (take note of the position/orientation for when you re-assemble....even take a digi photo to refer to !?!).....
......then just do jam removal & clean out in much the same way as for the top loader.
In all cases, don't force too much or be too brutal, gentle and patient works best, try to judge where the jam is caught and work with it slowly......you may need to cut jammed threads, just ensure all are removed before you re-assemble.
Feb 15, 2008 | Singer Featherweight 132Q Mechanical...
Handwheel is stuck
NEVER force a newer model machine. Everything inside is plastic and WILL break. Remove the needle, bobbin, bobbin case, and unthread the machine. See if the handwheel turns. If it doesn't, several things could be wrong. The lower end machines won't have belts to come off, they will be fully gear driven. If it is a better machine, it might be a belt problem. Small pieces of thread could be stuck in a gear mesh somewhere. A gear could be broken. It is possible for a gear to break on the first use.
Dec 01, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Kenmore 11206 / 11306 / 11506 / 11606 Logo
43 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
