I have a lady Kenmore washing machine that when you put the temp on cold cold, it will first pour warm water through the front liquid despenser and then it will fill most of the way in cold from the back. The water is warm. How can I get it to just do COLD WATER ONLY???
  • 481 Answers
This is the way it was designed. cold water will not dissolve the detergent in the dispenser completely. if you want cold water only then connect cold water to both the hot and cold connections in the back of the machine.
Posted on Jul 16, 2008
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
Why maytag neptune washer water pouring out soap dispenser door?
Either there is a sock stuck between the inner tub and the water
inlet to the tub or more likely you have been using to much liquid detergent and cold water wash all the time . This can cause the supply tube below the dispenser to be plugged up. Have fun cleaning it. Warm wash should always be used. Detergent needs the heated water to work properly .
only other possibility is mice building a nest if the washer hasn't
been used in along time.
May 09, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore front load washer leaking by liquid despenser
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore Washing Machines
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Bleach and fabric softner despenser liquids not being used.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Cold water starts and stops when washing
sounds like your washer has an auto temp. control if so the washer mesures the temp of the water and put in the manufacture set temp for that setting this board could be bad alowing only cold water to come into the machine. you could also have low hot water pressure at the washer be sure the hot water is turned all the way on. you may want to check to make sure no trash is in the hot water side of the water valve there is a screen in there where the hose conects you can remove that screen and clean it im sure one of these solutions will help you
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
How to drain liquid chlorine?
Get as much as you can out with a towel, then flush the rest with cold water. Just pour it in and dry it out with a towel until you are able to pour water in it and it go out the dispenser like normal. After you have gotten the dispenser cleaed out you will need to get the detergent out of the machine before using it. Start a cycle with cold water. Let it start washing, when you see suds forming pour in a little vegetable cooking oil. This will kill the suds. Keep doing this through the cycle. After the suds are gone and the cycle is done, run it through another cycle with hot water. If you have no suds you are done. If It still suds up by the end of that cycle, run the cold wash and vegetable oil again.
You should be ok by running one cold and one hot, just watch it and add a little oil to kill the suds.
The cooking oil trick works with dishwashers too if you ever put the wrong detergent in them.
Please reply if you need any more help.
Oct 23, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
