Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Shuts down automatically with red light
After using our Mitsubishi DLP TV for about 2.5 years, this morning suddenly it shuts down. If I turn it ON, first green light appears, then it flashes for a while, after that it shuts down and a red light appears.
What could be the reason? Do I need to change any light inside? Unfortunately my guarantee from Mitsubishi is over. Thanks for your help.
  • 3 more comments
  • peaceinmind Jul 16, 2008
    I pressed menu (as there is no button called 'device) from front panel for 8 secs and then the red light goes away. It doesn't give any two digit code. After that if i try to turn on the tv, it is showing the same green light and followed by a red light.
    Any more suggestion?
    Tult is still the same.
    Result is still the same.
  • troublmaker Jul 22, 2008
    my unit is about the same age and the exact same issues happened this evening. i tried holding the buttons for 8 seconds and no code was displayed. have you confirmed it is only a lamp? i did purchase the extended warranty, but of course i cannot locate the paperwork. please comment how you fixed your unit (do it yourself or take it to a tv repair) thank you!
  • J4PROUCTION Aug 01, 2008
    I HAVE BEEN HAVING THE SAME PROBLEM WITH THE RED LIGHT INDICATOR FLASHING A CONSTANT RED. I TOOK OFF THE PANEL AND CHECKED THE LAMP WHICH WAS FUNCTIONAL. I LET THE TV REST AND POWRED IT BACK ON AND STILL THE RED LIGHT INDICATOR STILL SHOWS. I REPLACED THE BULB ABOUT A YEAR AGO AND THE TV JUST RECENTLY STARTING HAVING THE RED LIGHT INDICATOR ON FOR SERVICE. IM SO FRUSTRATED WITH MITSUBISHI BECAUSE THIS IS THE SECOND TV I HAD TO REPLACE DUE TO MALFUNCTIONS.
I had the same problem.  Changed the lamp and still have the problem.
Posted on Oct 10, 2008
I have a mitsubishi wd-52327. Power light come on then a loud vibrating sound for a few seconds then after a pause it does it one more time then red light. I did the input and menu button for 8 seconds and got a code of 12 (no error detected check power supply). In my research I found a site called www.nodevice.com and downloaded a misubishi service manual for 9.95 euro.it has the error codes. for the person looking for error code of 44, it says (dvi cable between fmt and engine disconnected) Any suggestions appreciated. Lamp has been changed.
Posted on Sep 11, 2008
  • Mitsubishi Master
  • 8,617 Answers
Push device and Menu in on the front panel together and hold for 8 seconds and see if the led blinks a two digit code. As it may be the lamp or quite possibly the Power PWB capacitors if it blink a 3 4 code.
Posted on Jul 16, 2008
  • Sonny Berry
    Sonny Berry Jul 16, 2008
    Some models have a input button instead of device,If yours has input. Press input and menu both in together for 8 seconds.
  • Sonny Berry
    As long as a error code didnt come up, youre most likely only need a new lamp.
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Sep 26, 2016 | Mitsubishi WD Televison & Video
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
540 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
