How can i run C language on Asus M2N VM HDMI motherboard
When i start it gives a beep and d screen goes black and then nothing happens and it gets back to normal windows....plz help how can i run C language(a dos based) on Asus M2N VM HDMI motherboard plz help.....thanx in advance
  • harryy Feb 07, 2009
    in my system c language is not run plz suggest me how can solve this problem my system config: asus m2n motherboard
  • 550 Answers
My favorite answer to C questions is http://www.microsoft.com/express/vc/
M$ are giving away Visual C Express, a windows C & C++ development environment & support it
But if you have a favorite you wish to use read on::
  • many compilers/interpretors require the source file name in the command line or exit with nothing to do
    assuming your c interpretor is RUNC.EXE runc sourcefile
  • try running the c compiler/interpretor from a command prompt instead of directly typing the name in a shortcut,
    start
    run
    Cmd
    runc (or runc sourcefile)
  • or try compatibility mode for a windows98/95 program (dos ran pretty well under win98se) until you find something that works
    right click the shortcut that launches the c compiler or c interpreter,
    properties
    compatibility
  • or load win98 in a virtual machine and code on that (as a last resort)
  • development is easier, there are a bunch of notepad replacements for windows that support code highlighting for c so will make syntax checking simple
Posted on Jul 16, 2008
ASUS M2N VM DVI trouble
You must replace the processor cooler, the fan on it has aged and it's no longer doing its job properly. And use a good thermal paste.
BTW that software was designed to notify you of the temperatures and nothing more, reinstall it immediately.
Jul 09, 2010 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
Power switch & reset switch hookup
This should be your manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socketAM2/M2A-VM/e2975_m2a-vm.pdf
Page 1-32 Has your connections.
Hope this helps :)
Mar 08, 2009 | ASUS M2N-MX Motherboard
Problem whith asus m2n motherboard
ok one problem could be your power wattage make sure its 450 watt or above also check all jumpers on the motherboard
Nov 12, 2008 | ASUS M2N-E SLi Motherboard
Support DX10
Nope, it is a DX9 integrated solution - not good for gameing
Integrated Nvidia® Geforce®7Series Shader model3.0 DirectX 9 graphics processor
Maximum shared memory of 256 MB
Supports RGB with max. resolution 1920 x1440 (@70Mhz*32bpp/75Mhz*16bpp)
Supports DVI-D with max. resolution 1920 x1200 (@60Mhz)
Jun 04, 2008 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Video card installation
You will need to pay close attention to how many beeps & if their short or long. Asus uses the Award BIOS. Beeps are a part of POST. Power On Self Test. Open the link below to find out what your beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Dec 18, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
492 people viewed this question
David Payne
David Payne
