Question about Motorola Mobility H700 Wireless Headset
Using h700 as a PC headset
What do I need to do for this? Thanks for your help!
--Vijay
  • lawrd Jul 21, 2008
    Hi!
    I am not having trouble connecting to my phone... I want to use it as my PC headset. It seems to pair with my PC but I'm unable to see any available services on the device... :(
  • Anonymous Jul 24, 2008
    I have the same problem
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Posted on Jul 20, 2008
How do I switch on Motorola H700 wireless headset. Mine is not coming on
Hi, do you have the manual with you?,If you do you can use itto know how to charge the blue tooth device,i think the battery is a little bit low and will need to be charged forlonger hours for it to be able to power up.
So you can use the manual to see how to charge the device.
Hope it helped .
Fell free to pass your comment .
Thanks for using fixya...
Jan 13, 2011 | Motorola Mobility H700 Wireless Headset
H700 charges fine, dies fast
You need to Change its battery For Your Head Set . Only solution is battery Change.
Mar 15, 2008 | Motorola Mobility H700 Wireless Headset
I changed phones and do not have the passkey for H700?
Hi,the passkey for your h700 headset is "0000".this is the default passkey which will work for the pairing of your phone with the headset.
Thanks and take care
Apr 30, 2010 | Motorola Mobility H700 Wireless Headset
Conect to an other phone.What PIN# to use?Motorola H700
Use 0000 for the H700. If you are pairing with an Iphone, steps are as follows:
Headset is off, with mouthpiece closed
Open Iphone and select Bluetooth to ON
Hold down the center button (usually blue light) so it shows purple,
Open the mouthpiece.
The Iphone should merge.
Mine did not ask for a PIN, but if your does, it's 0000.
Thanks to the solutions above for guiding me thought this.
Feb 07, 2010 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Bluetooth Headset
The password is on the H700 and can't be changed. It is 0000 (that is 4 zeros).
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Unable to pair with phone, needs the passcode for motorola H700
try The default settings Of 0000
Or 1-2-34.
Mike @ compurepair.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
73 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
