Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black&decker 19"electric switch
The wiring for the switch has 2 balck wires ans a red &white .the previous reply said the left side are for the red/white whires and the right is for the 2 black. my question is how do you determine what is the left/right side?
Thanks
    Champion:
  • 313 Answers
The black actuator that moves on & off facing up. looking at the switch terminal facing u. ok. all left side terminal for white & red. all right side terminal are for 2 black wire. if you have fax machine i can send u the wiring. dennisv53@yahoo.com
Posted on Jul 18, 2008
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Jul 06, 2010 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
In replacing push button switch INDAK 681064-01N I forgot to record the wiring sequence, please help
If you look at the switch with the pushbutton on the top, the white wire from the cord to the motor attaches to the upper left terminal, the red wire from the cord to the motor attaches to the lower left terminal (just below where the white wire attaches), the black wire from the cord to the motor attaches to the upper right terminal and the short black wire going to one of the two pins that plug into the extension cord attaches to the lower right terminal (just below the where the black wire to the motor cord attaches).
Jul 11, 2009 | Black & Decker 19" Electric Lawnhog...
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Switch connection
position the switch terminal facing you & the black round lever facing up postion.now all left side terminal are for red & white.
next step all right side terminal are for 2 black wire. doesn't matter the red & white are top or buttom as long as its in the left side only.
Aug 25, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Aug 18, 2008 | Black & Decker 19" Electric Lawnhog...
Black and Decker MM525 hard wiring diagram
the connection the are not right. top left side is for white wire.buttom left side is for red wire. top right side is connected to black wire from motor. buttom right side is for is going to the
extension terminal. good luck
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
Wiring problem
its unsafe to hot wire the switch. contact me at 204-783-7294 i will send you a wiring diagram ask for dennis
May 05, 2008 | Black & Decker 19" Electric Lawnhog...
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
99 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
