Computers & Internet Logo
Anonymous Posted on Jan 22, 2011
If u want to install this older version,first uninstall any later versions that are in your computer
Brian Sullivan
Level 3:
  • Microsoft Master 27,725 Answers
  • Posted on Jan 22, 2011
Brian Sullivan
Microsoft Master
Level 3:
Answers
27725
Questions
Helped
5666208
Points
79191
Yes this is correct
eg: if you have a internet explorer 8 installed on your computer and want to install ie6 you will have to uninstall ie8 first
another example is if you have direct x 8 and want to install direct x 7 you will have to uninstall direct x 8
but by doing so some other programs that need the later version will not be able to run correctly
hope this helps
How to Fix MS Office Error Code 1704 During installation?
What version of Office are you installing?
Method: 1
Unregister and Re-register Windows Installer
Press Windows key + R, in the Run Window type 'msiexec /unregister' without quotes and click on OK.
Press Windows key + R, in the Run Window type 'msiexec /regserver' without quotes and click on OK.
NOTE: There is a single space in between 'msiexec' and '/'.
Method: 2
Verify if an older version of Office is currently installed on the computer.
Browse to the location below and check if you find any edition of Office installed on the computer:
Click on Start, Control Panel, Program, Program and features
If you find an older version of Microsoft Office listed in Program and Features, you may uninstall the older version of Office from the computer using the article below:
Note: read the disclaimer before modifying the registry in Windows
1. For Office 2007: http://support.microsoft.com/kb/928218
2. For Office 2003: http://support.microsoft.com/kb/290301
Once the uninstallation is completed you may restart the computer to install Office 2010 and check if Office installs successfully.
I hope it helps. Let us know if you need further help.
Thank you.
I had to uninstall my norton 360, now I don't know how to re-install it. I used my automatic renewal but I couldn't access my norton account. They said to uninstall and then reinstall and I don't know...
I can help you re-install the Norton product on your computer.
Please download the latest version of Norton 360 from the link www.norton.com/n360s_5
double click the downloaded file and follow the simple installation steps
The installer will automatically detect any older version of Norton product and will remove it
You don't need to manually remove the older version
After removing the older version, the installer will restart
After restarting, the computer will install the latest version
You're done...
Regards,
Muhaim
I can't install a new Nero 9 that I purchased. Keeps saying it cannot open an msi file
Is there a old copy of Nero 8 or such like older versions installed on your computer? If this is so, try uninstalling the older version first from your computer, restart your computer, then install the newer version of Nero 9. If this solution didn't help you.. then let us know again by replying on this post so that we can give you other solutions to help you most.
1helpful
I cant install songbird 1.8.Everytime i am trying, the computer is asking the question that to uninstall the older version to install this version.I am clicking yes but nothing is happening
go to the control panel >> add or remove programs>> ...then uninstall ur songbird' all versions... then restart ur computer then try to install songbird 1.8....
regards
Why not run video
Videos on YouTube are streamed through Adobe Flash player. If you're having trouble playing and viewing videos YouTube, we suggest you install the latest version of the Flash player: this will allow you to easily play YouTube videos.
Here's how to upgrade to the most recent version of Adobe's Flash Player:
  1. Before installing the most recent version of Adobe Flash player, you will need to first uninstall any older versions of the Flash player you've installed in the past and currently have running on your computer.
    Please completely uninstall the version of Flash you're currently running, before upgrading to the most recent version. To uninstall Flash, follow Adobe's instructions, listed here. You'll need to download Adobe's official Uninstaller to remove Flash.
  2. Once you've uninstalled the older version of Flash, you'll be ready to upgrade to the most recent version of Flash.
    To upgrade to the most recent version of the Flash player, please follow these steps:
    1. Follow Adobe's instructions for reinstalling the most recent version of Flash.
    2. Once you've downloaded the latest version of Adobe Flash, please exit your browser.
    3. Finally, click to install the update that you just downloaded to your computer from the Adobe Flash site.
      Once you've done so, open your browser again and go to YouTube. You should now be able so successfully watch videos!
If the instructions above don't resolve the issue, please also try the following:
  1. Temporarily disable popup blocking software installed on your computer to test.
  2. Allow YouTube.com as a trusted site in your Firewall software.
  3. Ensure other applications like Quicktime, iTunes, Real Player, or Windows Media Player aren't set as the default streaming application, as this might affect the video player.
For Windows Vista users:
If the Flash uninstall / reinstall does not work this maybe due to a Microsoft Windows Vista permissions issue.
Please use the Windows button at the bottom left then the search function:
  • Go to: C:\Windows\System32\Macromed\Flash\.
  • Right-click on the following file: FlashUtil9b.exe or FlashUtil9e.exe.
  • Select "Run as Administrator" and install the update..
  • Restart your computer.
Please post your feedback and vote if the issue is resolved as per your satisfaction.
    if(document.getElementById('kb_ie7') != null) showLayer('kb_ie7'); if(document.getElementById('kb_ie7_win') != null) showLayer('kb_ie7_win'); if(document.getElementById('z_ie7') != null) toggleZippy('z_ie7'); if(document.getElementById('z_ie7_win') != null) toggleZippy('z_ie7_win'); if(document.getElementById('kb_ie') != null) showLayer('kb_ie'); if(document.getElementById('kb_ie_win') != null) showLayer('kb_ie_win'); if(document.getElementById('z_ie') != null) toggleZippy('z_ie'); if(document.getElementById('z_ie_win') != null) toggleZippy('z_ie_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_winvista')) showLayer('kb_winvista'); if(document.getElementById('z_winvista')) toggleZippy('z_winvista'); if(document.getElementById('kb_IN')) showLayer('kb_IN'); if(document.getElementById('z_IN')) toggleZippy('z_IN'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US');
Why wont my computer let me download adobe flash playaer
you might have and older version of adobe flash player installed on your computer.
Check it, and if you have try to uninstall it first before dowloading your new version
go to
Start
- Control Panel
- Add/ remove programs
then uninstall the older version
2helpful
3answers
Please reinstal norton all in one 360
uninstall the older version through add/remove programs http://spftrl.digitalriver.com/pub/symantec/tbyb/NAM/N360S300EN.exe
use this link and download and install the latest version
2answers
Microsoft Office small Business Edition 2003 keeps installing whe
try to uninstall the software and then clear the registries using a registry scanner then try to install the later version. If this dosnt work use an antivirus or a spyware remover
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
