Question about Canon S200 InkJet Printer
My printer printing nothing after trying evry thing
  • carol vance Jul 28, 2008
    printer won't print, comes on paper goes thru
    i've tried everything just won't print even with the cd
My printer will not print
Posted on Jul 22, 2008
Hye..i have lost my printer driver to install..so i need the software driver..
modal for printer sp2000 (canon) inject printer..tq..=)
Posted on Jul 21, 2008
My HP Printer wont Print. Please help.
i think that you have wrong printer pre-selected.try from control panel to find printers and with right click change the pre celected one.....
Apr 07, 2015 | HP Deskjet F340 All-In-One Printer
Brand new Casio HR-150TM pringting calculator will not print. It goes thru the motions, but acts as if there is no ink. I can touch the printing wheel and will have ink on my finger, but nothing on the...
There is a plastic protective strip on the printing area. You have to take the ink pad off to remove the strip. Then evry carefully put the ink pad back on. You may need to wiggle the ink pad back on to make sure the black AND red ink is fully engaged. Now if I could just find a manual telling me what the rest of the buttons are for. This user manual is terrible!
Aug 10, 2010 | Office Equipment & Supplies
WHEN PRINTING CAN'T FOUND PAPER JAM BUT PRINTER ERROR PAPER JAM WHEN PRINTING USING PRINTER CANON LBP-2000.
It is possible that your printer sensors are picking up dust or particles within its workings. 3 things you could try:
1. Get your hoover and hoover evry single part of the printer. Take apart all the parts that should be removes and hoover it out completely
2. Get a bicycle pump and blow air all throughout the printer. This is an attempt to blow away any problem causing foreign bodies
3. Take the printer in both hands and physically turn it upside down and give it a gentle shake, to remove or dislodge any larger objects that may have fallen into it.
Hopefully one of the above tips will solve your problem.
Kind Regards
a
Aug 10, 2010 | Computers & Internet
When i print in color there are 2-3 smudges (ab. 2 x 1 cm)at the same place evry time. When printin b&w there is no problem.
that only means that the nozzles of your printer for the colored ink are clogged by dried inks but for black, its not, you can try printing a nozzle check to prove or check that. and if you found out that it has missing lines, do head cleaning
Feb 11, 2010 | Epson Aculaser C1100 Printer
Printer has Half way Full ink but dosent use
These are the symptoms of a poor quality ink. If you have run the deep cleaning and alignment for the ink cartridges, I would replace the cartridges with OEM ink cartridges to clear the problem. Aftermarket inks are sometime not up to manufacturer specifications.
Try cartridges from LD Products. I've not had problems with their inks on my 5 different Canon printers.
Aug 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Tally 2280+. While printing, goes offline and displays paperjam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
Nothing prints on the paper
My Printer is doing the same thing try to print color and see if the color works im color works but only in pink
Oct 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
The printer prints nothing
maybe the printer is out of ink! or try printing again!
laser printer at home did the same thing, but when i tried it again it was fine!
Oct 16, 2007 | Lexmark P707 Photo Jetprinter InkJet
Canon S200 InkJet Printer Logo
104 people viewed this question
old marine
old marine
