Question about Sharp EL-1801P Calculator
Cannot Laod the paper
I do not know how to load the paperv Can someone please tell me ? i feel Dumb but I really just cannot seem to do this... Thanks Shey cannot load paper
  • nan7 Dec 30, 2008
    I want to change the tape
Look for a small **** in the rear/back - middle of calculator, under the hook that holds the roll of paper, not on top where the printer paper comes out.
Posted on Aug 29, 2008
IT GOES IN THE BACK, AND HAS TO BE PERFECTLY STRAIGHT. (CUT IT). HOPE THAT HELPS!
Posted on Aug 07, 2008
Casio FR-2650A Not Pulling Paper Through
See if the roller gear is jammed or rusted. A little wipe with WD40 may help.
Jan 27, 2012 | Casio FR-2650A Calculator
Loading paper tape
open the calculator, put the paper in, then put the end of the paper into the slot, close it and that should be it..
Apr 10, 2008 | Casio HR-8TMPlus Calculator
Loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
Jan 19, 2012 | Office Equipment & Supplies
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
I got this solution from someone else who had a problem. Just feed the paper in through the back of the unit into the ****. You kind of have to be persistent in guiding in and hitting the "feed" button at the same time.
Jul 24, 2008 | Canon P23-DHV Calculator
Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 10, 2008 | Victor 1230-2 Calculator
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
1. The end of the paper roll can be cut on either a straight-edge or angled slant. 2. Remove the top cover of the calculator. 3. Insert the paper into the narrow back slit on the back of the calculator so that it feeds under the black plastic plate. The slit is located on the outside of calculator. 4. Use the Paper FEED button to advance the paper up. 5. Replace the cover and feed the paper through the cover opening. Hope this helps. Slit for paper is not immediately obvious, so don't put yourself down.
Feb 19, 2007 | Canon P23-DHV Calculator
Sharp EL-1801P Calculator Logo
564 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
