Question about Panasonic KX-TG5632 Phone
Phone wont talk--it has talkingidfeatures
On the facing of the phone it says ringer off--
also i have the talking id on the "on"--but it still won't talk,,it only talks on the speaker phone...2 of these phones was purchased,, & I notice that the other pair works both on speaker & phone
  • 79 Answers
The ringer has to be on first. Usually the unit announces the caller’s name after the 2nd ring. If you turn on the answering system and set the ring count to “2” the unit does not announce the caller’s name. Set it for more than 2 rings for name announcement.
Posted on Aug 24, 2008
How to adjust the number of ring before the answering machine picks
If your instruction book is missing... select SETTING from MENU scroll down to RINGER .... u got it
Oct 04, 2014 | Sakar Talking Caller-ID Speaker Phone
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Sakar talking caller id doesn't work!! ringer doesn't work, have it on. taking caller id doesn't work. Need someone to help with this.
Did this just suddenly happen?If it did,unplug both the phone line and the power supply for about 5 minutes.The transformer needs to be unplugged from the wall.This is a common "reset" procedure for digital electronics which tend to lock up.Welcome to modern technology...lol.Plug everything back in.Digital is almost anything which can be programmed and a few other things such as your phone,video game consoles,modems,on and on.Whenever you have a problem of lock up or no power try doing this first.If this doesn't work,just comment here and I will get an autolink and reply ASAP.
Good luck,Greg
Nov 18, 2010 | Sakar Talking Caller-ID Speaker Phone
Cannot Hear the Ringer
could be set to "no ring" on the system, if so it will never ring, sounds like you need to talk to your helpfull sys admin!! ;-)
Dec 09, 2008 | Mitel 5220 IP Phone
Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
Oct 10, 2008 | Panasonic KX-TG2357 Cordless Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Phone
The ringer switch is on the back of the base next to the phone line connection that plugs in to the wall.
To set the clock, time and talking ID feature press the set button and then the up and or down button to the right of the keypad for your selection (above the hands free button)
Jan 28, 2008 | Innovage 1502084 Corded Phone
Sakar phone
I e-mailed Sakar International and got this response...
"We are sorry for the difficulties you are facing with the phone.
We suggest you unplug the phone and remove the batteries from the phone. Connect the phone back and insert the batteries after 10 minutes and check if the problem persists.
Thank you for using Sakar International, the leader in technology."
I haven't tried it yet.
Jan 22, 2008 | Sakar Talking Caller-ID Speaker Phone
Panasonic KX-TG5632 Phone Logo
206 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
