Question about Canon imageRUNNER 2200
Canon copier/ fax imageclass 2220: error #0322
It's saying "printer off-line," and is also giving me an error #0322 message. Any ideas on what might be the problem? thanks
  • Canon Expert
  • 1,326 Answers
It has to do with your network. Call your IT person to repair it.
Posted on Jul 18, 2008
  • Anonymous Jul 23, 2015
    Guess much? The real answer is a bad fixing assembly.
Canon 2220 "ROM ERROR" and won't work.
First Unplug the printer for 10 minutes. Then start your printer it will work fine.
Then execute eprom clear in Test mode.
If you still face the problem then there is a bad solder connection or a power surge. Loose wire is always possible.
Hope this helps.
Feb 15, 2011 | Canon imageCLASS 2200 Black and White...
Canon Image Class 2200 Error code 0322 Can you help me with this problem It will not print at all
this means that you have problem with fixing assy. Best solution would be to replace fixing unit.
And,... did you consider to buying new one,... try with Canon image runner 3225N. Its a NORMAL copier. :-)
Jul 06, 2010 | Canon imageCLASS 2200 Black and White...
Printer offline error code 0322
Sounds like the fixing film has gone bad..... and or the dc power supply could have gone bad in it. i would call a service tech to come out and take a look at it if you haven't already done so.
May 27, 2010 | Canon imageCLASS 2200 Black and White...
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Jan 20, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Error message on printer E000
E000 is a fixing unit problem. It could just be needing to be reset or replacement of the fixing unit or if that is not the fix it may coast more then it is worth.
Jun 11, 2008 | Canon ImageClass D880 Copier
Canon imageRUNNER 2200 Logo
284 people viewed this question
old marine
old marine
