Question about RCA RCR311B Remote Control
RCA RCR312W remaote control
My remote quit working and I can't find the directions to reprogram it. I need to know how to program my remote.
  • Anonymous Feb 28, 2009
    Problem Solver:
  • 8 Answers
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Posted on Jul 17, 2008
  • 3 Answers
Hold down the tv and power button until it stays lit. (on-off) then press play it will blink 10 times If the tv does not shut off press play again. whenthe tv shuts off press reversa until it comes back on then press stop. do that for all your applications.
Posted on May 24, 2009
Http://safemanuals.com/user-guide-instructions-owner-manual/RCA/RCR311W-_E rca put the wrong dam model # it should be rcr311w this is a link for the manual it worked fine for me
Posted on Aug 14, 2008
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Plis help with codes to control rcr312w
The RCA code finder can help: http://rcaaudiovideo.com/remotecodefinder/ . Use the drop down menu to choose the RCR312w and then the type of device you want to program. Then click Search.
For example: RCA TV codes to try are 10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
Alternatively, go to http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCR312W and click on the Support/Manuals tab. The manual and the code list are both available. The direct link to the manual is http://audiovox2.info/docs/common/RCR312W/RCR312W_OM.pdf . The code list is here: http://audiovox2.info/docs/common/RCR312W/RCR312W_OTHER_CL.pdf .
I hope this helps.
Jun 10, 2011 | RCA RCR312W Remote Control
Need universal remote codes for RCA Remote RCR312W. I am trying to program an Emerson VCR/DVD Player with the Universal RCA Remote (RCR312W) and need the codes to put in or how to do a code search.
1.Go to the url below
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR312W
2. Scroll down and select the "Support and Manuals" tab.
3. Click "Owner/User Manual" link
4. Click "Code List for RCR312W" link
Jan 20, 2010 | RCA 3-dev Universal Remote Remote Control
Reprograming an RCA for a new tv
just read the manual and put the codes for your new tv. or buy a universal remotes they
come with codes for any brand
Aug 18, 2009 | RCA RCR412C Remote Control
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Feb 15, 2009 | RCA Universal Remote Control
I have a new RCR312W TV remote. I have lost directions
Someone had posted a solution to manually program the remote. The information came from RCA website. It worked fine. I still would like the code numbers for my remote. I have a LG TV that is about a year old.
Feb 14, 2009 | RCA Universal Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
RCA RCR311B Remote Control Logo
1,746 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
