Question about Ice Cream Makers
Danby icemaker not pumping water
I have a danby dim1524 which behave similarly to yours. After the initial warm up, it tries to pump the water to the ice tray (you can see the pump image at the screen console). Then it failed and showed the error (exclamation point inside a triangle). Did you fix your problem? If you how? What was broken?
Thanks,
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Posted on Aug 18, 2008
This problem can occur if the unit sits for extended periods without use. The pump head will sieze and the pump will not start. Eventually, the motor can burn out, but, for now, when the unit is trying to pump, you can 'talk' to the pump head (tap it with a screwdriver handle to 'jar' the sediment from the impeller) and (at least in my case) it will start. Has worked for two years in a row, after extended storage. Be carefull with the cover off (right rear), as there is high voltage present when the unit is plugged. in.
Posted on Jul 14, 2009
Taylor c712 with pumps one side sounds like it is pumping and looks like its pumping but when you use it there is no mix in the barrel
Hi Megan,
The first thing I would do is tear the machine down, sanitize and rebuild and properly lubricate everything. If you have a spare kit, you should install all new pump o rings and seals (Parts 4, 5, 6, 8 and 14 in the schematic). Hopefully, it is either improperly lubricated o ring, or a worn out seal and that will fix it.
The plastic pump parts do wear out over time (Parts 3 and 4) and so do the stainless steel pump sleeves (Part 1). If seals and lubrication don't correct the issue, you can start looking closer at the pump parts.
I have the tune up kit available here.
http://www.softserveparts.com/i-26471781-x49463-81tune-up-kit-for-taylor-c712.html
Schematics of the pumps are here with prices and part numbers.
http://www.softserveparts.com/p-37364-exploded-parts-views-for-taylor-c712.html
Soft Serve Parts C712
Jun 18, 2017 | Taylor Ice Cream Makers
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Whipped cream continues to squirt out slowly after initial squirt, after charging
Cut off valve under nozzle either jammed or needs replacing, try cleaning it with warm soapy water first.
Oct 29, 2013 | Isi Profi Whipped Cream Maker - 1 Quart
Pump cutting off
the pump is not suppose to run all the time.it should cut off until you pull draw handle . when handle is pulled pump should run for ten seconds or so.
May 06, 2012 | Taylor 8756-33 Soft Serve Two Flavor Ice...
Air/mix pump wont shut off on vanilla side model #8756
sounds like your pressure switch is bad on your unit
Jul 21, 2011 | Taylor 632-33 Ice Cream Maker
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
Fill water light comes on while the water is full on my BlueIce model 80533 Icemaker
I had the same problem with my machine bought from Costco - did you know that Costco will refund or exchange your item no matter how old or how long out of warranty?
They pledge to make you happy or you can have your membership money back.
we took our 28 month old Blue ice model 80533 ice maker back to Costco and got a full refund and then bought a brand new one. The new one was £30 more but when we complained and then threatened our membership (they did not want to do an exchnage as it was more expensive now) they relented and gave us an exchange.
we understnad from friends that it could eb 10 years old and Costco will still refund your money, so try this.
Aug 08, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Ice Cream Makers Logo
380 people viewed this question
Top Ice Cream Makers Experts
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
