Question about HP Pavilion zd8000 Notebook
HP ZD 8215 Laptop Start-up Problem.
After shutting down the laptop yesterday, the computer will not start back up. On Start-up using AC adapter--(Same power supply as used for over 1 year), the only activity that happens is that the computer beeps 2 times when pushing the power on button.
All of the indicator lights light up as normal except for the power on light--(the light on the power on key)
This light just blinks off and on.
On normal conditions, this light stayed on all the time when power up.
I have unplugeed the power cord, removed the battery and pressed the power key for 1 minute to discharge the unit and applied power again.
But the same reults.
  • 50 Answers
2 beeps with no post means either you have a memory failure or the motherboard has failed
Posted on Jul 17, 2008
Hp dv5 not charging or booting up
Try this,
remove the battery and try with the ac adapter. Generally we trying to see if its battery or ac problem. Laptop should start cause the source of the power is the 120v electricity converted for laptop use through the adapter.
If its still not starting, then its adapter issue, just buy another one from a local computer store or amazon according the model of the laptop
Jan 12, 2014 | HP Pavilion dv5-1138nr Notebook
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Lenovo y410 laptops turns off suddenlty while using it for long hours
hi
is the computer dissipating excessive heat from bottom ? is the heatsink fan working (is it blowing out air from fan on the side ? if not, then replace the heatsink fan. This shut down occurs to advise you that something is not working well , and to avoid damage to the CPU and/or mainboard, its letting you know that.
if the fan is working fine-- are you on the computer while the AC adapter is NOT plugged in ? Are you fully charging the battery before you use the notebook without the AC adapter ? If you are NOT using the AC adapter, running on battery life only, then do this : shut down the notebook, disconnect the power adapter, remove the battery back up from rear of notebook.
reconnect the AC adpater and start the computer -- perform normal function on the computer, run it and work with it for a few hours. if the same issue occurs, (unwanted shut down) , then perhaps the AC adapter is faulty, which is not charging the battery to full capacity.
let me know what happens-- i'd appreciate your feedback w/o receiving bad rating
Nov 15, 2010 | Lenovo 3000 Y410 Laptop
HI, My Hp DV9000 will turn on but shuts off the
There could be a few possibilities here, first the ac adapter needs to be checked for voltage at the tip, it has to be between 18.5 and 19.5 volts. The battery is most likely dead or has dead cells which will not carry a charge. The third problem could be the motherboard. Try leaving the battery out and just run the laptop off the AC adapter....if the laptop runs fine , then the battery is bad and sending signals to the motherboard causing a shutdown. If the laptop is still shutting down or refusing to start, then there maybe a problem with the voltage resulator in the charger brick. If the battery and charging brick are in good condition, then the laptop may be getting a thermal shut down signal from the processor because of an overheating condition. The processor heats up immediately, if the laptop has been run overheating for some time, the thermal grease on the processor can be cooked off reducing the efficiency of heat bleed off, thus causing a shut down to protect the laptop from a terminal meltdown. Try using compressed air and blow out all the ventilation grills and compartment openings to clear out debris, hair and dust.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Zd 7000 even with the battery or power adaptor the lights on but can not power on the on off switch not working and all the lights on
Dont know why you are trying to shut down with the power button,. But that said. right click the desktop, select properties, go to the screen saver tab, then power. In power go to the advanced tab. There you will have drop downs with options. WHEN it press the power button- shut down - do nothing - hibernate - etc.
Nov 20, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Shuts down
First: Please always provide what are your Operating System, what are you doing when that happening and all the information you think that could be usefull to help solve the problem.
What are the symptoms?
Any message?
Blue screen?
Jan 30, 2009 | HP Pavilion zd8000 Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
HP Pavilion zd8000 Notebook Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
