Question about GoVideo Go Video DVD/VCR Combo
Recording problem When recording from my camcorder I get a prompt that tells me "cannot record, defective disc after 5 min or so. This is most frustrating so I would like some help with recording from my camcorder. Thanks, Sandra
    Champion:
  • 224 Answers
I would suggest using the manual,you can download one,just type in name and model+manual ,to google
Posted on Jul 28, 2008
Disc error on hitachi camcorder
it may be that you need to format the disc this option should be located in the menu somewhere if it does not automatically ask you when putting a new disc in the camera. i hope this helps you.
Dec 23, 2012 | Hitachi Video Cameras
Disc error occurred repair disc now.if i repair will my recordings be cleared.vdr-d100
If you replace the dvd drive assy in the vdrd100 it wont destroy the recording on your discs and the other recordings should play just fine, provided that the discs arent defective or the recordings on them are ok. I hope this helps
Sep 04, 2010 | Panasonic PV-GS500 Camcorder
6 seconds into recording the following message appears: write error - to recover disc, presss OK. having pressed 'OK' the screen then shows 'Disc Loading' message - this takes time and uses up battery...
It turned out to be a simple case of a defective disc, which, for some reason failed to work satisfactorily. I replaced it with a fresh disc (JVC 30 min DVD-RW) from he same batch and it formatted ok and worked well too. I checked that it had recorded and I was pleased to say that it had. So let's hope that that was the cause of my problem, because the camcorder is now just out of warranty.
Many thanks for your halp in this matter.
Regards.
Jim Stringer
Oct 13, 2009 | Samsung VP-DC161 DVD Camcorder
Videos are no longer showing on mini dvd in camcorder.
please try to play the DVD disk in a DVD player. I dont think that the video was wiped , but i think the camera has a defect in the playback software.
rgds,
Luwangula
Sep 14, 2009 | Canon DC310 DVD Camcorder
Pls help me
Tough to say for sure with out giving me the model number. Some of these models have a 5 second record feature. It's never good to just open the door during recording or you could lose recording information. press record pause first and wait for it to complete it's processing time.
Dec 27, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Disc playback
are u sure about the media type tat is supported in ur cam.
Jun 16, 2008 | Samsung VP-DC161 DVD Camcorder
Panasonic NV-gs50
where can i get drivers for the NV-GS50
May 09, 2008 | Panasonic NV-GS50 Mini DV Digital...
Invalid disc prompt,whenever i install a disc
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Jan 09, 2008 | KLH CDR2000 2-Disc CD Recorder
Disc error
if you get a disc error, DO NOT TRY TO REPAIR the data.
When you get a disc error, turn the camera off, turn the camera back on. When prompted to repair the data, select NO.
The camera should prompt you to Format the disk, select no.
you should go back to a normal camera screen, at this point push the FINALIZE button on the outside of the camera to finalize the disc.
This is your only option to save the data.
Never try to repair the bad data, it never works.
I have done this on two occasions, and it worked both times.
Dec 02, 2007 | Hitachi DZ-GX3200A DVD Camcorder
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
GoVideo Go Video DVD/VCR Combo Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
