Question about Intel Motherboard
Bios doesn't recognise harddrive or dvd rewriter
Tried your solution, every time i plug the ide lead in the dvd or harddrive, i lose power to both, something is shorting out, cant think what
    Problem Solver:
  • 5 Answers
Get a new ide cable
Posted on Oct 23, 2008
    Genius:
  • 1,605 Answers
Sound like th cable is reverse.
read the manual first, make sure the momories are in the correct orientation. DO NOT FORCE IT.
un-plug the hard drive and the DVD. try to run on the computer. if it turn, then plug in one item at a time.
Since Intel manual doesn't tell you which is pin1 on the IDE cable. you nee to make sure the cable with red bend on one side is plug into the IDE socket on the motherboard label pin1 and the other end is plug into the IDE hard drive facing the power plug.
SATA cable can go in only one way.
Posted on Oct 21, 2008
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
I LIKE TO KNOW HOW TO KNOW WHETHER THE PRODUCT IS STILL FUNCTIONING OR NOT? PLEASE ADVISE. SHOW ME HOW TO DO THE CONNECTION OF THE IDE CABLE TO THE HARD DISC AND THE POWER CABLE? HOPEFULLY THESE ARE NOT...
No product support question is stupid, Peter.
1) An IDE cable should be plugged in with the Number 1 socket hole in the IDE cable's connector, going on the Number 1 pin on the harddrive.
Number 1 pin on an IDE optical drive, or harddrive, is next to the 4-pin power connection.
http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Illustration which shows the back of an IDE (PATA) harddrive.
See the area marked as IDE Connector?
Two rows of pins.
Next over are the Jumper pins in the Jumper Block.
Finally, next to the Jumper Block is the 4-pin power connection.
To make sure the IDE flat ribbon cable, is inserted into the harddrive in the correct position, a Locating Lug is usually on the IDE flat ribbon cable's connector.
A small rectangle, or two bumps side by side, on the top edge of the connector.
http://en.wikipedia.org/wiki/File:ATA_Plug.svg
This Locating Lug lines up with a cutout, in the circuit board of the harddrive.
A Locating Notch.
Sometimes there isn't a Locating Lug.
In this case look at the side edge of the IDE cable for the faint Red stripe.
This red stripe is on the same side as Number 1 pin.
http://en.wikipedia.org/wiki/File:Nappe.svg
So when you go to plug the IDE cable in, make sure the Red stripe is facing the 4-pin power connection.
Goes for an optical drive (CD/DVD drive), or a Harddrive.
(On the motherboard there are usually two IDE headers. {Connectors}
One for the Primary IDE device, a Harddrive, and one for the Secondary IDE device.
Usually an optical drive.
Next to the Primary IDE connector on the motherboard may be PRI, or Pri, or Primary, or IDE 1.
{ In TINY letter/numbers }
Next to the Secondary IDE connector on the motherboard, may be SEC, or Sec, or Secondary, or IDE 2.
Sometimes only the Secondary connector is marked. This tells you the other connector is the Primary connector.
Number 1 pin is towards the marking. Primary, or Secondary.
The Red stripe goes towards the marking on the motherboard )
Also;
There are two rows of pins on the back of the Harddrive for the IDE cable.
With a cursory glance it may look as though there are two rows of 20 pins.
There is not.
One pin has been removed. One row only has 19 pins.
Generally, but NOT always, the matching socket hole in the IDE cable's connector, is blocked off with a plug.
An IDE cable only uses 39 socket holes even if there are 40 shown.
Also; NOT a good idea to put a Harddrive, and an Optical Drive, on the same IDE cable.
BIOS looks to see which drive has the Master Boot Record.
Windows master boot record.
This is on the Harddrive.
BIOS will look at both, the Harddrive, and the Optical Drive.
This slows the computer down, for one.
For two, BIOS may not find which drive has the master boot record, with both drives on the same IDE flat ribbon cable.
Harddrive goes to the Primary IDE cable.
Optical drive/s go to the Secondary IDE cable.
2) As for the power cable it is a 4-pin standard Peripheral power cable.
Often misnomered as a 'Molex' cable.
[Molex was the model name given by the first company to produce this connector.
It stuck.
Kind of like referring to an open-end wrench as a Crescent wrench ]
It is also a STANDARD 4-pin Peripheral power cable, because there two 4-pin Peripheral power cables.
4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note in the center photo the shape of the connector.
The top two corners are rounded.
Only plugs in, in one direction.
{The Yellow wire is a 12 Volt wire.
Red = 5 Volts
Black wires are Ground wires }
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used this power cable for a Floppy Drive.
Newer computers use it for a Card Reader.
Regards,
joecoolvette
Oct 01, 2011 | Computers & Internet
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
Mother board came with pc with 160 gb hard disk I have added 500 gb hard disk in addition thepc isworking well and it cannot recogognice the extra hard disk and I have to tighten the jumper connection of...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Dec 16, 2010 | Asrock P4I45GV R5 Motherboard
Laptop doesn't recognise DVD rewriter - LG
If your laptop dont recognise dvd rewriter it may be due to many reason it may either due to Ide cable or a registry issue or a hardware issue .Try following steps :
1 make sure you have correctly inserted the IDE and Power Cables. Fault of putting the IDE cable in the wrong way around make this happen.
2 Make one drive the the Master and the other the Slave, don't set both to Cable Select.
Is it not recognizing the drives in the BIOS or Windows? Try changing IDE cables?
If BIOS, have you gone into the BIOS and verified that the drives are detected? Try changing the BIOS settings for the IDE Channels from AUTO to CD_ROM. At least then, from a hardware viewpoint, you are forcing the system to recognize.
3 If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players.
4 If its a registry issue then try following steps but remember first take back up of your registry
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Mar 24, 2010 | Computers & Internet
Connecting harddrive and dvd rewriter
if you want to have two IDE drives in a single cable must set up as a teacher and the second as a slave.
the teacher is on one end of the cable and slave middle... but remember to set the pins as shown in the units
Jul 17, 2008 | Intel Motherboard
Installing harddrive and dvd rewriter
change the jumper setting of dvdv to cable select or slave and remain the hd to master
Jul 16, 2008 | Intel Motherboard
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
Oct 27, 2007 | Intel DG965WH Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
