Question about Sony Handycam DCR-DVD201 DVD Camcorder
To watch my recorded video on tv
I have connected the video camera and connected it to my television set and put on channel 7 but no pictures come on the television
    Sergeant:
    Champion:
  • 319 Answers
Connect your camera to the "video (1)" input of TV
Posted on Aug 01, 2008
We have a Philips DVD3460 recorder. Where in the manual does it inform us on while Watching T.V. and DVD is recording another T.V. channel?. Would love to know " how to do this"?
It depends on your setup.
Think of the Philips DVD3460 as an independent, standalone television set. It has its own analogue tuner, and its own video input.
If you have an analogue RF TV signal (coaxial cable) going in to the Philips DVD3460, you can watch whatever you want on any other TV connected to the TV signal coaxial cable, since the regular analog TV cable carries all of the channels.
However, if you are using a cable or satellite box and use the "Video in" function of the DVD recorder or just have the DVD recorder tuned to channel 3 or 4 to record from a cable or satellite box, you can't record one channel and watch another unless you have a second cable box..
Apr 24, 2011 | Audio Players & Recorders
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am having trouble in connecting the new dvd recorder . I think ,I am missing some thing on the initial set up to receive the channels our present configuration is ... 1.R F cable input to set top box,...
I found your model information on a site which provided something I was going to ask you if I could not find it.DVD recorders need either a digital input from a cable box or a self-contained digital scanner(yours does not have this).So,you need to hook up as follows,External cable into cable box input,cable box output into DVD recorder input,DVD recorder output to TV coaxial cable input(usually labeled ant.)the screw on connector anyhow,you should know what I mean it seems.In this configuration,you should not need to turn on the DVD recorder to watch TV without recording because they usually have a bypass mode when there is no power on the DVD.If you have picture in picture(PIP),you should be able to use the main source to record and switch over to the PIP channel if you do not want to watch what you are recording.Do about a 10-30 second test of that just to make sure though so you don't end up all messed up.Oops.My bad...you do not have PIP.As long as the cable box is tuned to the channel you want to record,you should be able to use the TV's tuner to watch something else with no problem.When doing this on VHS recorders,sometimes the screen would get fuzzy and you would have to press the TV/VCR vutton on the VCR remote.I do not know if a DVD recorder will do it or not as I have yet to buy one,but when you do your test recording,you can mess around with whatever you want to see what happens so you will be fully prepared when you do it.If you need more help or have a problem/question,just comment here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Sep 26, 2010 | Coby DVDR1280 DVD Recorder/HDD Recorder
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
I have a security camera outside that runs to tv with rca cables. i want to record to a vcr which is connected to tv by coax. i cant get it to record the camera picture. can u help?
The coax connection is one-way RF only from the VCR to the TV. It cannot be used to record from TV to VCR.
Run the RCA cables to the Line or Aux input on the VCR first. Watch on the TV through the coax connection to the TV. You can watch even when not recording the camera signal on the VCR by setting the output of the VCR to Line instead of a channel.
Another option would be to connect a component (RCA) output from the TV (if there is one) to the VCR Line or Aux input.
Dec 16, 2009 | Office Equipment & Supplies
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Television will not program channels 2-7
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
Oct 09, 2006 | RCA F27669 TV
Sony Handycam DCR-DVD201 DVD Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
