Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Loud humming or buzzing when set is in operation
We noted the the buzzing is located in the area of the lamp. As soon as the lamp ignites, the buzzing begins and continues to get louder as time passes.
We changed out the lamp but the errant sound begins with the lighting of the new lamp. We suspect the motor on the color wheel.
  • 1 more comment
  • Anonymous Jul 23, 2008
    Same
  • LLHowie Oct 09, 2008
    Same thing happens to me and the picture colors change and distort. Can a color wheel be changed by me or do I have to get a technician?
  • Big Dog Jim Nov 04, 2008
    Does anyone have a manual on how to replace the color wheel on a HL-P4663W 46" DLP?
This happened to me as well, the color wheel had to be replaced
Posted on Sep 03, 2008
  • 2,336 Answers
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Posted on Jul 16, 2008
How do I open the3 fuse box under the hood of my 02 dodge neon,it keeps humming
PDF]Owners Manual - Dodge
https://www.dodge.com/download/pdf/.../2004_JR41_Stratus.pdf DodgeThe interior lights will come on when you open any door, ... There is a door lock switch on each front door trim panel ...... the hood release lever located under the left side of the ...... and neon signs. ...... NOTE: Using the "3" range while operating the vehicleunder ...... The fuse access panel is behind the end cover at the left.
were is the fuel pump reset button for a 2001 dodge neon?
www.cargurus.com > Questions > Dodge > Neon
CarGurusJul 26, 2011 - were would i find the reset button on my dodge neon i need help badly is there ... I would check the fuse under the hood and relay. ... Fluid, spray into your intake with engine off and throttle open .... 2002 Dodge Neon For Sale.
[PDF]WIRING DIAGRAMS - Ertyu.org
www.ertyu.org/steven_nikkel/neonfsm/2000/EPL_8W.pdf
what causes the humming noise thats coming from my fuse box in our ...
https://answers.yahoo.com/question/index?qid...
Feb 4, 2011 - I am in a Alpha Ideal 34 ft rv. The fuse box on wall started humming a noice lastnight. Coming right from in the area of the switches. What could ... Buzzing noise coming from fuse box/lights flickering?
Aug 25, 2013
Breaker/Fuse box noise please help?
Sep 11, 2011
Why is my home's fuse box making a loud constant buzzing noise ...
Jan 3, 2011
My house fusebox has a buzz sound?
Jul 14, 2009
More results from answers.yahoo.com
Feb 05, 2016 | Jeep 02 - 05 Chrysler Sebring, Dodge Neon,...
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Tv sound buzzing lamp
Contact any service technician.
Oct 09, 2013 | Mitsubishi WD-Y65 65" HDTV
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
On off switch does not work somtimes set goes on and off comes on with sound but no picture un plug it and sometimes it works fine
i,
Well basically Sam sung most common parts that go out are,
LAMP: The generic lamp will go from 3500 to 4500 hours and a Phillips lamp will go for 6000 to 8000 lamp hours,
How It Works The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp. The lamp works with the ballast to project light into a light engine that separates the colors of the light, then recombines them with an image. The image is then reflected on the back of the TV and then onto the screen. But you need to listen carefully for any strange noise like (CLIKING,HUMMING,BUZZING,WHIRLING SOUNDS) that will help you narrow down whats is wrong with your TV because the BALLAST witch is the board in charge of sending the correct amount of current to your lamp could be weak and will not power up you will hear a clicking or electrical humming Also the color wheel is a common part that goes out on Samsung and that will give you a vibration and a loud whirling sound,you can get more help and real good prices at http://www.discount-merchant.com/?click=52978 good luck and keep us posted
Nov 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
545 people viewed this question
Jerry Greenberg
Jerry Greenberg
