Question about Samsung HCM4215W 42" Rear Projection Television
1986 tv won't turn on
So I know my TV is old, but it works great. I had it on, and I was moving furniture, so I unplugged it (when it was still on).
When I plugged it back on, I expected it to turn on. It didn't. I pushed the button, and it made the turn on static noise, but no picture.
I then pushed the button a few more times. It always makes the static noise, and sometimes a fraction of a second a white-light flashes across, then nothing. No picture.
Did I break the picture tube or something?
Is it cheap to fix? -or- should I just buy a new one?
  • ellipses Jul 16, 2008
    So I am assuming I did break the tube right?
    Ohh well, if anyone else has suggests on where to get a good cheap TV that would be awesome. Becuase I'm a college student and have about -zero dollars to work with.
    THANKS!
  • 2,323 Answers
Great TV you bought.
At this point I would say it might not even be worthy to get the TV fix due to the age unless you can do it yourself.
In my opinion you can save the money from the repair to buy a new TV.
Hope you do not upset with the messenger LOL.
Posted on Jul 16, 2008
  • Jaime Hernandez Jul 16, 2008
    I wouldn't say the tube is broken but more likely a solder joint became open when you moved the TV.
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
I have a 50" phillips
hi need more information on the fault, thanks
shaun
Apr 16, 2017 | Televison & Video
I unplugged my Sanyo DVW 7000 DVD/VCR 4 head Hi-Fi system for about a half hour, while we were moving furniture. When I plugged it back in I couldn't get it to work. I can turn it on manually and get the...
I am not sure if you unplugged all the cables from your VCR to your TV, If so double check the hook up. When you unplugged the POWER to the VCR the memory was lost. Try and find the menu or set up on the remote. Again the audio out from the VCR needs to be hooked to the audio in on the TV and the video out from the VCR needs to be hooked up to the video in on the TV. Keep trying !!!
Jul 28, 2010 | Sanyo DVW-7000 DVD Player/VCR
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
Dropped tv and now i only get purple and yellow as the tv colors
hi..It sounds like your tube Shadow Mask may have got
magnetised and need to be degaussed.turn off your TV
at the mains and unplug it for at least two three hours,
after that time power up your TV it should degauss the
tube at power up.
try this out..
thank u..
kindly rate my response..
May 06, 2009 | JVC AV-36260 TV
TV won't turn on
Hi There,
Try unplugging the TV and wait 5 minutes, plug it back in. Let me know what happens.
Mar 29, 2009 | RCA Televison & Video
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Nov 18, 2007 | Curtis-Mathis CM27101S TV
Samsung HCM4215W 42" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
