Question about Intel Motherboard
NEW MOBO MSI K9N SLI V2
Molex 4 Pin Square Hi There Please Anybody Than Can Help
I Am Upgrading Computer Running Into Problem
Mobo Msik9n Sli V2
Cpu Amd Athlon 64x2 4600
In The Procces I Found That I Need A 12 V 4 Pin Square Power Cord Which I Dont Have From My Psu However In The Mobo Istallation Manual It Says I Must Power The Cpu 4 Pin 12 V
Do I Really Need It ?
I Can Only Get Power To The Cooling Fans For About 2 Seconds And Nothing Boots??
Thanks
    Sergeant:
  • 287 Answers
The short answer is YES you need the additional power to the 4 pin molex.
Post your power supply brand and specs along with the copmplete spec of your PC and I'll be able to give some further advice regarding best option for you
Posted on Jul 17, 2008
Is the MSI-K9N SLI-Platinum (MS-7250) capable of running an HD capable video card?
I would recommend upgrading your RAM to 2GB or even 4GB before investing into HD video card. It might be jerky. Your processor should be ok for it as it is.
Jul 21, 2010 | MSI K9N Platinum Motherboard
Mainboard drivers for MSI k9N Neo v2 for Windows
type in the mobo mdel number in google it'll take you straight to it
Feb 24, 2010 | Computers & Internet
My k9n sli-2f v2 won't power up anymore. when i disconnect the 4 pin atx cpu power plug the power supply powers up. of course no response. anyone know the problem? my warranty expired 5 months ago all...
Hi
Thank you for your query
From what you are descrbing the motherboard and/or the CPU have blown and will need to be replaced
Please book PC into a reputable PC shop for replacement
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 16, 2010 | MSI K9N Platinum Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
MSI K9N4 SLI-F / Vid Card question
Hi, for the best graphics always go for dual graphic cards. This is the best way to obtain realistic 3D effects. The onboard audio chips is every bit as good as stated, MSI systems are equal to the best but at a lower price. The only change I can see that you need to make is to install a better power supply. A minimum 500w is needed with your system and if your budget allows then anthing up to 600w. Have fun with your games. Regards mistyman
Sep 21, 2007 | Intel Motherboard
New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Mar 27, 2007 | ASUS P5N32-SLI Deluxe (890552603794)...
Intel Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
